Reconstruct the image
hi
I am using spartan-3AN to receive data from IR camera. Then data is sent to a client application in the computer via TCP/IP offload engine. The FPGA is used to provide interface between the TCP/IP offload engine and the camera electronics. The problem is that although the image is acquired from the camera but it keeps continuously moving. The FPGA Block RAM is used as FIFO buffer to temporarily store the data and then data is trnaferred to TCP/IP offload engine via 64 KB SDRAM. I need help on how to stabilize the image which is recontructed in the computer.
Teacher eteam00
Re: Reconstruct the image
Please define 'stabilise' a bit more precidely.  Without reading your thoughts (it's easier to read your posts), I have no idea what you have in mind.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher rcingham
www.lmgtfy.com/?q=image+stabilisation+algorithms
And as you want to run them on the PC, this thread is off-topic.
