Participant prakashvenugopal
Re: Reading and Writing
Hi Experts,
      I had added the 7 bit counter in the simulation screen. Please look at the simulation screen shot. All q[6:0] are in undetermined state  Please refer the attachment.
VHDL code:
entity strobe_pulse_generation is
port ( clk16M6 : in std_logic;
Q : out std_logic_vector(6 downto 0);
dval : out std_logic);
end strobe_pulse_generation;
architecture Behavioral of strobe_pulse_generation is
signal counter: std_logic_vector(6 downto 0);
signal enable1u66: std_logic;
begin
process(clk16M6)
begin
if clk16M6 ='1' and clk16M6'event then
if (counter >= 54) then
counter <= "0000000";--(others => '0');
else
counter <= counter + 1;
end if;
end if;
end process;
Q <= counter;
enable1u66 <= '1' when counter = 0 else '0';
process(clk16M6)
begin
if (counter < 28) then
dval <= '1';
else
dval <= '0';
end if;
end if;
end process;
end Behavioral;
Test bench code:
ENTITY strobe_pulse_generation_tb IS
END strobe_pulse_generation_tb;
ARCHITECTURE behavior OF strobe_pulse_generation_tb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT strobe_pulse_generation
PORT(
clk16M6 : IN std_logic;
dval : OUT std_logic
END COMPONENT;
--Inputs
signal clk16M6 : std_logic := '0';
--Outputs
signal dval : std_logic := '0';
signal Q : std_logic_vector(6 downto 0) := "0000000";
-- Clock period definitions
constant clk16M6_period : time := 60.24 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: strobe_pulse_generation PORT MAP (
clk16M6 => clk16M6,
Q => Q,
dval => dval
-- Clock process definitions
clk16M6_process :process
begin
clk16M6 <= '0';
wait for clk16M6_period/2;
clk16M6 <= '1';
end process;
 end;
The letters which is marked in bold are statements which is added for counters to be added to the simualtion.
V. Prakash
Instructor
Instructor
Did you read the last line of my previous post?  hint: uninitialised state
-- Bob Elkind
SIGNATURE:
Summary:
Hi Experts,
       From the simulation screen shot, we found 16m6 clock is running continuously. dval and q[6:0] are in uninitialised state 'U'.We have to initialise that using a '0'. ? How to iniatialise that? Please let me know.
V. Prakash
Hi Expert,
       Can you please explain in details on your last post. hint: uninitialised state
V. Prakash
Advisor joelby
Advisor
In ISim, uninitialised registers take on the state U. You can't increment a counter if it's uninitialised - what's the value of "uninitialised plus one"?
Initialise your counter register, and perhaps every other register, to some known value.
Hi Expert,
               After initialising the counter and dval to a known value, i am able to simulate the dval pulse of 3.32 usec. Simulator screen shot to your reference. Now i will proceed to simulate the Lval Pulse.
V. Prakash
Hi Experts,
        I had simulated the dval and lval pulse.
Dval --> on time= 1.66 usec and off time= 1.66 usec (3.32 usec)
Lval --> on time = 849.9 usec and off time = 146.02 usec is achieved.
Please refer the dval and lval pulse on the simulation screen shot. In this, during lval raise, dval is also raising.
Please refer the comm. interface pulse timing diagram, during lval raise, dval is in falling edge. how to do this? please let me know.
Here is the VHDL code for dval and lval generation:
port ( clock : in std_logic := '0';
       dval : out std_logic := '0';
   lval : out std_logic := '0');
  signal counter: std_logic_vector(6 downto 0) := "0000000";
signal lvalstate : std_logic := '0';
signal lvalcount : unsigned (7 downto 0):= "00000000";
  begin
process(clock)
begin
  if clock ='1' and clock'event then
    else
    end if;
  end if;
end process;
Q <= counter;
process(clock)
begin
      dval <= '0';
    else
      dval <= '1';
    end if;
  end if;
end process;
process(enable1u66)
begin
if (enable1u66 = '1') then
case(lvalstate) is
when '0' =>                             -- Keep LVAL low for 44 cycles
if (lvalcount = 43) then               -- LOW period is over
lvalstate <= '1';
lval <= '1';
lvalcount <= "00000000";            -- reset the counter
else
lvalcount <= lvalcount + 1;
end if;
when '1' =>                                      -- Keep LVAL high for 256 cycles
if (lvalcount = 255)  then                                    --HIGH period is over
lvalstate <= '0';
lval <= '0';
else
end if;
when others =>
end case;
end if;
end process;
   end Behavioral;
thanks,
V. Prakash
Hi experts,
          Please refer the attached comm. interface diagram for during lval raise, the dval is in fall.
thanks,
V. Prakash
Instructor
Instructor
Prakash,
You have big trouble:  You don't understand your own code.  Forget the LVAL and DVAL pulses.  You need to learn how logic gates and registers work, and how to describe these basic logic functions in VHDL.
How are you going to learn this?
Until you learn these things, you are completely dependent on others who write code for you, instead of you writing your own code.
I was doing you no favours by writing code for you.  I should have realised that you were using us (and edaboard) to avoid the effort to learn these skills for yourself.  I apologise for this, this was a mistake.
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
Look through your code.
  • in which lines are DVAL changing from 0 to 1, and from 1 to 0?
  • what logic terms control DVAL value?
  • what logic terms control when DVAL value changes?
  • in which lines are LVAL changing from 0 to 1, and from 1 to 0?
  • what logic terms control LVAL value?
  • what logic terms control when LVAL value changes?
Let's see if we can learn a thing or two about how logic works and understanding VHDL.  Are you ready to learn?
-- Bob Elkind
SIGNATURE:
Summary:
Hi Experts,
if counter < 28 then
dval <= '1';
else
dval <= '0';
end if;
This can be chaged to:
dval <= '0';
else
dval <= '1';
end if;
am i right? Please verity.
V. Prakash
Advisor joelby
Advisor
Why don't you verify it yourself? It'll only take thirty seconds to check in ISim - much faster than you can post to ask on the forum ;)
Hi Experts,
         I checked that in ISIM. For the code, during lval is raising, dval gets fall
Thansks,
V.  Prakash
Hi Experts,
          Now i am able to simulate the dval --> 3.32 usec pulse and lval --> Ontime=849.92 usec and Offtime= 149.02 usec.
But when i check in the board by downloading the bit file. Only dval is generated. there is no required lval is generated.
What may be the cause for the Problem? Please let me know. Please give some idea to debug this lval generation.
Simulation Screen attached for lval. Please refer.
Here is the VHDL code written:
end strobe_pulse_generation;   architecture Behavioral of strobe_pulse_generation is   signal counter: std_logic_vector(6 downto 0) := "0000000";
signal lvalstate: std_logic := '0';
signal lvalcount: std_logic_vector (7 downto 0):= "00000000";   begin
process(clock)
begin
  if clock = '1' and clock'event then
    else
    end if;
  end if;
end process;
Q <= counter;
process(clock)
begin
      dval <= '1';
    else
      dval <= '0';
    end if;
  end if;
end process;
process(enable1u66)
begin
case(lvalstate) is
lvalstate <= '1';
lval <= '1';
else
end if;   when '1' =>                                      -- Keep LVAL high for 256 cycles
lvalstate <= '0';
lval <= '0';
else
end if;   when others =>
end case;
end if;
end process;
end Behavioral;
V. Prakash
Advisor joelby
Advisor
Double check that your ping constraint for lval is correct. You can't always trust the user manual to be right, so it's sometimes worth referring to the schematic diagram too.
Send some of the other test signals whose behaviour you understand out to pins, such as enable1u66 and a few of the LSBs of your counter. Or use ChipScope Pro to monitor all of these and compare it to your simulation.
Instructor
Instructor
There are a number of things you can check.
If you have never checked the LVAL pin before, and proven that the pin assignment and board layout are correct, then the obvious possibilities are:
  • board layout error
  • pin assignment error
  • you are probing the wrong FPGA pin
-- Bob Elkind
SIGNATURE:
Summary:
Hi Experts,
       I am using avnet spartan 3A evaluation board.
As you suggest, i had checked the enable1u66 signal taking out to the Port pin-->on time= 130 Ns and off time= 3.3 usec
dval port pin is working with 3.3 usec pulse. so I had checked the dval and lval swapped with the port output pins. But still dval  pulse is coming out as 3.3 usec, lval is coming out as  ON time= 4 usec and Off time= 77 usec something like this.?
There is no chance of board layout error, pin assignment. and also i am probing the FPGA pin correctly. What could be the cause for this problem.?
V. Prakash
Instructor
Instructor
Well, that is an improvement.  You first reported that there was no pulse output on LVAL, and now you see a pulse output on LVAL.
Now you need to change the logic which is controlling LVAL, correct?
-- Bob Elkind
SIGNATURE:
Summary:
Hi Expert,
         Yes. You are right. Now i have to look into the lval generation logic part.
Lval Generation Code:
process(enable1u66)
begin
case(lvalstate) is
lvalstate <= '1';
lval <= '1';
else
end if;
lvalstate <= '0';
lval <= '0';
else
end if;
  when others =>
end case;
end if;
end process;
For every 3.3 usec, the enable1u66 gets high. after that, we are checking the lval state. Inital value of lval state = '0', lval = '0'
So it will get into the Case '0' => in this, when lval count = 43,  lval <= '1' and lvalcount = 00. here case state changed to '1'
this will keep lval low for 43 count x 3.32 usec = 149.76 usec.
            In case '1' => when lval count = 255, lval <= '0' and lvalcount =00. here case state changed to '0'.
This will keep lval high for 255 count x 3.32 usec = 846.6 usec. so this will be done continously. Logic is found to be correct. I am able to simulate the same. But it is not working as required pulse ? Is there any mistake here.?
V. Prakash
Advisor joelby
Advisor
I'm struggling to follow along closely enough, but the enable1u66 signal was originally intended to be asserted once every 1.66 usec, not every 3.32 usec (the clue is right there in the name). However anything is possible now and it was impossible to see what was going on at the usec scale from from your last screenshot.
With a very simple circuit like this, the simulation will almost certainly reflect the true output. From your last posts, it's not really clear if you're getting an incorrect lval pulse or no lval at all.
If lval is incorrect: look at the simulation, zoom in, and verify all timing precisely. Look at what the counter value is at the instant when it changes. If it changes at the wrong time, update the counter check logic to match exactly what you want.
If there's no lval output: post your UCF and tell us exactly which pins on the Avnet Spartan-3A board you're probing.
Instructor
Instructor
process(enable1u66)
begin
The signal enable1u66 is not a clock, and it is not a latch enable.
Look at your previous code, and remember how a clocked process is constructed in VHDL.
It looks like this mistake originates from incomplete Verilog => VHDL code translation.
Looking at the Verilog code I posted, the LVAL signal changes state on the same clock edge as DVAL's 1=>0 transition.  If I am correct, the code should work as specified by Prakash -- if it is translated correctly from Verilog to VHDL.
Prakash, this problem demonstrates that you do not yet understand the language you are reading, copying, and editing.  This takes time, but it is absolutely essential that you learn
  • what are process sensitivity lists and what do they mean
  • what is a register, what is a clock, what is a clock enable
  • what does if clk'event mean
These are basic constructs of the VHDL and Verilog language.  You shouldn't expect to progress very far at all until you can write code on your own, with an understanding of how it works, rather than simply copying words and phrases without an understanding of their meaning.
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
I believe that -- at some point -- the VHDL code was (poorly) translated from Verilog code which I posted, which was based heavily on your (joelby's) code.  The enable1u66 signal is instantiated in my code (after torturing *your* code) as follows:
wire enable1u66// pixel-rate, single-cycle clock enable pulse
// Assert the clock enable every 55 cycles, a pixel-rate pulse
assign enable1u66 = (counter == 7'd28);
So enable1u66 has become a 3.3uS period signal.
By the way, I just now edited post #17 in this thread to add the highlighted comments:
// enable1u66 clock enable pulse coincides with last clock cycle before dval 1=>0 transition
always @(posedge clk16M6)  dval <= (counter < 7'd28);  // dval has 28/27 duty cycle
and
  if (enable1u66)  // advance at pixel rate, output changes are coincident with dval falling edge
    case(lvalstate)
Hope this clears up a detail or two.
As noted previously in this thread, Prakash is not yet ready to retire his VHDL language primer.  This will all sort itself out, given enough time and patience.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher rcingham
"Prakash is not yet ready to retire his VHDL language primer."
Too right. The sensitivity list for that LVAL process is badly wrong if it is meant to be a combinational process, and if it meant to be a clocked process it is all just plain wrong.
"If it don't work in simulation, it won't work on the board."
Instructor
Instructor
In the predecessor verilog code from which this was translated, the process in question is a clocked process.  The translation to VHDL shows a serious lack of understanding of the VHDL language at the most basic level.
Prakash, you need to learn and understand
  • what is a register (or flip-flop)
  • how a register works
  • how is a register used
  • how to describe a register (or flip-flop) in VHDL
  • the meaning of the various parts of the VHDL register description
  • the usage of the various parts of the VHDL register description
There is much more to learn, of course, but these are bits which have been shown lacking through your work in this thread.
As you go through VHDL learning exercises, you should ask yourself each of the 6 points listed above until these questions are so well understood that they require little thought.
Here is a web page with a few links to online VHDL learning tools.
You will learn more efficiently and more effectively with an instructor or guide -- someone to look over your shoulder and correct you in person.
-- Bob Elkind
SIGNATURE:
Summary:
Hi Experts, Yes. You are right. The clocked process should have a clock in the process sensitivity list. dval and lval should get sychronised with the same clock. Please refer the attachement Lval timing. process(clock) begin if (enable1u66 = '1') then case(lvalstate) is when '0' => -- Keep LVAL low for 44 cycles if (lvalcount = 43) then -- LOW period is over lvalstate <= '1'; lval <= '1'; lvalcount <= "00000000"; -- reset the counter else lvalcount <= lvalcount + 1; end if; when '1' => -- Keep LVAL high for 256 cycles if (lvalcount = 255) then --HIGH period is over lvalstate <= '0'; lval <= '0'; lvalcount <= "00000000"; -- reset the counter else lvalcount <= lvalcount + 1; end if; when others => lvalcount <= "00000000"; end case; end if; end process; When i placed the clock in the process sensitivity, the observation is like this: Dval --> perfect 3.32 usec pulse Lval --> On time= 424.3 usec and Off time = 73.66 usec But Required Lval --> On time= 3.32 usec x 256 = 849.9 usec , off time = 3.32 usec x 43 = 146.08 usec see, Half the time of LVAL ontime = 849.9/2 = 424.95 usec is obtained while simulation. Half the time of Lval off time = 146.08/2 = 73.6 usec is obtained while simulation. Thanks, V. Prakash
Hi Experts,
Yes. You are right.The clocked process should have a clock in the process sensitivity list. dval and lval should get sychronised with the same clock. Please refer the attachement Lval timing.
process(clock)
begin
case(lvalstate) is
lvalstate <= '1';
lval <= '1';
end if;
lvalstate <= '0';
lval <= '0';
end if;
when others =>
end case;
end if;
end process;
V. Prakash
Instructor
Instructor
VHDL lesson from a Verilog guy...
This should look familiar:
process(clock)
What does the second line mean?
-- Bob Elkind
SIGNATURE:
Summary:
Re: VHDL lesson from a Verilog guy...
Hi Expert,
               Yes. You are right. I missed out to check the raising edge of the clock in lval generation.
Process(clock)
if (clock = '1' and clock'event)
Now i am clear:
clock'event is used to specify the change in clock value and clock=1 is the high state of the clock. When they are both used together it signifies rising edge of the clock.
V. Prakash
Teacher rcingham
process(clock)
-- Bob Elkind
We grizzled VHDL pros tend to use
if rising_edge(clock) then
end if;
instead...
There is also a falling_edge() function.
Historian
Historian
end if;
instead...
Who you callin' "grizzled," Willis?
NOW GET OFF MY LAWN!
Oh, wait, I live in the desert. I don't have a lawn.
NOW GET OFF MY DIRT!
Seriously, there's actually a Real Good Reason why the rising_edge() function is preferred over the event-detect and test-for-state in the old idiom. It's an exercise left to the reader to learn this Real Good Reason.
