sebastianro
Register read/write access
In my code I have a register that is written with data read from SPI (register is 32bit and loaded after all the 32 bits have been read from SPI in a temp register). On the other side the register is read via PCIe interface. My question is: do I have to worry that the data can be metastable at the time of the read, because its just being written? Should I use something like read on posedege, write on negedge? If not why? The register, I guess, would be implemented as a set of flipflops so the new data would be loaded in parallel....
eteam00
Professor
Professor
No, the clock domain is the same, this should mean that I don't have anything to worry about, right?
Correct, there is no risk of metastable condition.
Because I store the serially read data from the SPI in a buffer and place it in the register only after the 32 bits have been read I'm guessing all the read bits would be new. Is my assumption incorrect?
If register read logic and register write logic are both in the same clock domain, your assumption is correct.
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Professor
Professor
If the PCIe port can be reading data from a register while the register is being written, then indeed you need a mechanism for metastable avoidance.  If you design your system so that the PCIe port will only read data when the data is stable, then you do not need to worry about metastability.
Can you guarantee the data being read is stable?  If not, you'll run the risk of reading garbage, even if you insert ranks of registers to avoid "metastable" states.  You won't be able to guarantee that all 32 bits being read are either "old" data or "new" data.
I'm assuming from your description that the SPI logic which writes the data has a different clock than the PCIe port which reads the data.
-- Bob Elkind
SIGNATURE:
Summary:
sebastianro
eteam00
Professor
Professor
-- Bob Elkind
SIGNATURE:
Summary:
