ntropy
SP601 Max Voltage on J13 GPIO Pin
I have a SP601 starter kit board and was wondering if I can place a 15v signal without frying the board.  Thank you for your help.
mcgett
Don't do this.  You will fry the FPGA.
ntropy
What do you suggest I do?
eteam00
Professor
Professor
  • Well, I suggest consulting the Spartan-6 Datasheet DS162 for maximum IO pin input voltage specification.  See Table 1.  If you exceed this voltage, you risk damaging the FPGA.
  • Then consult the SP601 schematics for VCCO voltage used for the FPGA pins connected to J13 GPIO.  This will guide you to which IOSTANDARDs are available for use.
  • While in the DS162 doc, check the logic input thresholds (VIN for HI/LOW) for the various IOSTANDARDs you can select. See Table 9.  If you violate these voltages (for the IOSTANDARD you select), you risk misinterpreting the logic "1" and logic "0" states of your input signal.
Would you like me to look these up for you, or do you want to look these up for yourself?
-- Bob Elkind
SIGNATURE:
Summary:
ntropy
Looking at Spartan-6 Dataset DS162 it seems that the max input is 3.3V.
Looking at the SP601 schematic for the J13 GPIO, I/Os pins support LVCMOS25 signaling--3.3v.
Looking back at Spartan-6 Datasheet DS162 Table 9 results:
I/O Standard: LVCMOS25
VIL Min:–0.5
VIL Max:0.7
VIH Min:1.7
VIH Max:4.1
VOL Max: 0.4
VOL Min: VCCO – 0.4
It looks like the max input is around 4v without hurting the board, is this correct?  If I have a 15v signal input, is there an internal way to regulate the power coming on, or do i just need to create a voltage divider to drive down the signal?
eteam00
Professor
Professor
The GPIO pins go to IO banks with VCCO=2.5V (not 3.3V).  See page 2 and 3 of the board schematics.
To be precise, 4.1V for commercial temp range parts.  DS162 Table 1
No.
A resistor divider should be effective.  You may want to add a diode to clamp the divided signal to the 2.5V rail to protect against overshoots.
Warning:  if the 15V signal "0" level is greater than 0.3 * 15V (4.5V), then a simple resistor divider may not be reliable.  If this is the case, you could use a series zener diode or a true comparator for more reliable level shifting.  Your first step is to measure the "0" and "1" logic levels of your "15V" signal.
-- Bob Elkind
SIGNATURE:
Summary:
ntropy
You stated the first step is to measure the 0-1 levels.  Ranging on the signal, I have 13-15 and 14-15; therefore a 1volt to 2 volt differential.  Do you suggest a 1N4372A zener diode or would a LM317 be a better choice with equal resistors therefore the voltage will be equal to around 2.5v?
sebastianro
Sorry to be a bit off topic but how did u come up with 0.3?
eteam00
Professor
Professor
This isn't off-topic in the least.  It's an excellent and pertinent question.  Two-step process:
  • Check the VCCO compatibility list of UG381 Table 1-5.
  • Cross-check with DS162 Table 9.
Options for (input only, VCCO=2.5V, VCCAUX=2.5V, no VREF) are:
IOSTD          VIL(max)   x VCCO
LVTTL          0.8        .32
LVCMOS33       0.8        .32
LVCMOS25       0.7        .28
LVCMOS18       0.38       .152
LVCMOS12       0.38       .152
I2C                       .25
SMBUS          0.8        .32
SDIO                      .125
I've listed only the VIL specs, not the VIH specs.  Of the IO standards listed above, the ones most tolerant of a voltage offset in the LOW state are:
  • LVTTL
  • LVCMOS
  • SMBUS
All of these 3 have similar VIH(min) specs:  2.0V or 2.1V.
Summary:  Downscaling the 15V signal to 2.5V, and selecting LVTTL | LVCMOS | SMBUS for the input IO std should work OK as long as the signal's "0" level is no more than 0.3x of 15V before downscaling.
A "0" level on the 15V input signal which is greater than 0.3x the maximum "1" level (presumed to be 15V) would be marginal for a simple resistor divider which scales 15V down to 2.5V.
This all presumes that "1" level is reliably close to 15V.  There is still room for problems if the "1" level is not consistent in this regard.
NOTE:  This all presumes single-ended signal.  If the "15V" signal is actually a differential pair with an ~12V common mode offset, then none of this posting is in the least bit useful.
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Professor
Professor
Is your "15V signal" a differential pair?  What do the numbers "13-15" and "14-15" represent?
Please be as concise and unambiguous as possible in your response.
-- Bob Elkind
SIGNATURE:
Summary:
sebastianro
bassman59
Historian
Historian
Use an open-collector output comparator with its threshold tied to midway between the two levels, and connect the output to the FPGA I/O pin's VCCO via the usual pullup resistor.
eteam00
Professor
Professor
Already asked, and already answered.  See message #9 in this thread.
Did you not understand the answer?
-- Bob Elkind
SIGNATURE:
Summary:
sebastianro
Ah, sorry, I didn't see the answer. Thanks for the explanations
