Visitor akshitsood
SPARTAN6 LX45 CSG484
HI
I am planning to use the device XC6SLX45-3CSG484. For assigning pin list i am using Xilinx PLan Ahead v 11.5.
NOw while assigning pins to a bank i assign LVCMOS25 input to a bank with VCCO and VCCAUX 3.3 and all other signals in the bank are LVCMOS33. So it gave a warning saying Either VCCO or VCCAUX must be 2.5V to support the LVCMOS25 inputs in a bank with all other LVCMOS33 signals.
So am i allowed to have feeed LVCMOS25 inputs.
What will be the effect if i change the VCCAUX to 2.5 V on the rest .
Teacher eteam00
Re: SPARTAN6 LX45 CSG484
There are some signaling standards which require VCCAUX = 3.3V.  Specifics are found in DS162.
LVCMOS25 input requires either VCCO=2.5V or VCCAUX=2.5V.  Reference DS162, Table 7, note 1.
If the source driver for an LVCMOS25 input signal can tolerate 3.3V, then suggest you use LVCMOS33 input with an external R pullup to 3.3V.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor hallovipin
It said correctly. If you need to have LVCMOS25 inputs either you have to make VCCAUX 2.5 volts or the bank which has LVCMOS inputs you power it up with 2.5 V instead of 3.3 Volts.
I am not sure but I think the best solution will be powering all your VCCIOs with 3.3 volts and VCCAUX with 2.5 volts.
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
