SPI Device part Number for Spartan 6 xc6slx16
Hi All,
Please tell me the part no.of the spi for spartan xc6slx16..
I tried m25p128.. once it worked and the next time, program failed...
Someone please tell me device part no..
Thankyou
Scholar u4223374
Re: SPI Device part Number for Spartan 6 xc6slx16
Could you explain what you're trying to do?
If the problem is that you tested an M25P128 chip with a Spartan 6 and it died after the first attempt, then that suggests that you've got board problems. Obvious ones would be power supplies out of spec, static shock, signal integrity, etc.
If the problem is that you told the tools that the flash chip was an "M25P128" and it didn't work, then the solution is that you need to find out what sort of flash chip is actually on the board. This is much easier for you than for us, since you just read it off the chip.
