SelectIO Wizard (lvds) input clock question
I use camera  link receiver template of selectIO wizard 4.1 to generate a ip core on spartan 6. my question is that it seems the input clock in the ip core (CLK_IN_P & CLK_IN_N) is not the very clock of  normal flat lcd lvds clock. for example,  the frequency of clock pair is 40MHz for SVGA and the serialized data frequency is 280MHz. but selectIO wizard assumes the input clock is 280MHz? because I saw it divided the input clock to 1/7 in the source code.
Re: SelectIO Wizard (lvds) input clock question
I didn't use the template but refer to xapp1064 instead
Historian
Historian
Wow, that is weird.
i am also facing the same problem.at my device side, i am getting the clock 1/7 times my original clock.have u solved the problem.plz help me.
could you show the wizard snapshots?
