Visitor jbeesoniq1
Skipping Spartan6 IODELAY2 Cal
If I simply want to dynamically walk through the 256 delay taps rather than choose one static value, can I *not* perform the calibration (and not provide IOCLK)?  For example, I would like to treat the IODELAY2 as an async delay to deskew some signals to improve margin... much like I could do with Virtex4/5/6 (there a 0->31 or 0->61 range).  The signal I wish to allow some deskew on has a bitrate is less than 188Mb/s as required for cal.
In this case, I do not care what the actual per-tap delay is, only that I can walk through dynamically adding up to a max delay of X... where (30% of 13.568ns) <= X <= 13.568ns (for speed grade -1).
Thanks!
Teacher eteam00
Re: Skipping Spartan6 IODELAY2 Cal
There are only two variable delay modes for IODELAY2, and both require calibration.  This is described (with astonishing clarity) in UG381 section "I/O Delay Modes".
Don't blame me, I'm just conveying the bad news.
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
Visitor jbeesoniq1
Hi Bob,
True, a good bit of clarity, it was more a question of omission.  The cal sets the max tap, but if you don't cal I was hoping the max would be defaulted to 255 so I could simply dynamically walk the 0 -> 255 range.
Thanks!
