rhykie
Spartan 2 FPGA (xc2s100)
I'm new to FPGAs (and so to the Xilinx family of FPGAs), so I am asking whether there are any built-in/pre-programmed Verilog modules or variables in Xilinx Spartan-II (XC2S100) FPGA board. This is because I was doing an example of a Verilog code designed for a partan-II FPGA and I came across some module instantiations of the modules which were not in the code, such as IBUF, CLKDLL and BUFG. Their syntax were highlighted, and I was not sure whether they are built-in in Verilog or in the FPGA board for I/O ports.
Cheers
gszakacs
Instructor
Instructor
These are not "board defined" but rather primitive structures of the FPGA.  You can find
a description in the Libraries Guide, which is part of the software manuals for your
version of ISE.  If you are using a more recent version of ISE, then the guides are
available from the ISE Navigator in the Help menu under "Software Manuals" or
"Online Documentation"
HTH,
Gabor
-- Gabor
gszakacs
Instructor
Instructor
HTH,
Gabor
-- Gabor
eteam00
Professor
Professor
If you are using a more recent version of ISE, then the guides are available from the ISE Navigator in the Help menu under "Software Manuals" or "Online Documentation"
Warning, the most recent versions of ISE do not support the Spartan 2 family, but Spartan 3 and later are supported.  I believe ISE 10 was the latest version to support Spartan II (2).
- Bob Elkind
SIGNATURE:
Summary:
gszakacs
Instructor
Instructor
Thanks, Bob.  Version 10.1 is "recent" in my book :)
And yes, 10.1.03i is the latest version for Spartan 2 support.
Support for Spartan 2 (non-E version) goes back at least as far as the old Aldec-based
Foundation 4.1 tools.  Documentation in the older versions is organized differently.
Gabor
-- Gabor
eteam00
Professor
Professor
Version 10.1 is "recent" in my book :smileyhappy:
How are those floppy drives holding up for you, Gabor?  :)
SIGNATURE:
Summary:
