Spartan 3 Configuration issue
HI,
I have a designed a Spartan 3 XC3S400 configuration based board, but the Spartan 3 IC is not getting detected. I can use the same JTAG circuit to configure another CPLD(while getting Spartan 3 out of the Boundary Scan chain). I have checked the supply and ground pins for the Spartan 3, and they are correct. When I try to initialize the chain through Xilinx ISE 10.1, it cannot detect the device. The device IDCODE read is all zeros. When getting the IDCODE, all the JTAG pins are receiving signals properly, but the FPGA does not respond with proper TDO signal. I have even replaced the Spartan 3 IC, still there is no response.
Please help me with this.
Anshuman
Re: Spartan 3 Configuration issue
Check FPGA TDI input for shorting to ground.
Hi Kurgan,
I have already checked the TDI pin. It is not shorted to GND, neither are any other JTAG pins. Any other things I should check?
Anshuman
