Newbie yossivideo
Spartan 3 and Spartan 6 - Frame Buffer Throughput
I'm designing a system that requires video frame buffer that can support 1080p (1920x1080) @60Hz with 24bpp.
In both Video starter kits (for the Spartan 3 and 6) the maximum resolution in the demos is 720p (74.25 MHz pixel rate).
Does anybody try to run a frame buffer (VFBC) with speeds of 148.5MHz writing and reading from the same DDR SDRAM?
Yossi
Instructor
Instructor
Re: Spartan 3 and Spartan 6 - Frame Buffer Throughput
You need roughly 373MB/sec bandwidth to your frame buffer
1920 * 1080 * 60FPS * 3Bytes/pixel
If you want to read and write concurrently, double that to around 750MB/sec.
S6 -2 speed grade supports DDR-667.  You'll need a 16bit wide DRAM to provide enough bandwidth (plus headroom) for a full duplex frame buffer.  If read and write are non-overlapping, you could get by with a 1 byte wide DRAM.
How is your video coming on-chip?  A -2 speed grade S6 doesn't have the ISERDES bit rate required for 1920x1080p/60 TMDS (e.g. DVI or HDMI).  I haven't checked on -3 speed grade vs. 1080p/60.
- Bob Elkind
SIGNATURE:
Summary:
Newbie yossivideo
Bob,
Thank you.
The video is streamed as 24bit, HS, VS, DE & CLK.
When you say DDR-667 you mean DDR2 @ 333MHz?
Where did you got the info that the "S6 -2 speed grade supports DDR-667"? does -3 will be even better?
Do you think that if I'll implement 2 memory controllers, one with 16 bit DDR and the other 8 (or 16) bits DDR i'll be 100% safe or it'll be enough to use one 16 bit 400 MHz DDR2 or DDR3?
Cheers,
Yossi
Instructor
Instructor
Yes, I meant to write DDR2-667, which uses a 333MHz clock with DDR data signaling
Where did you got the info that the "S6 -2 speed grade supports DDR-667?
Check the datasheet, doc DS162.  Requires extended VCCint for DDR2-667 support on -2 speed grade.
-3 speed grade supports up to DDR2-800, with extended VCCint
You haven't described your design requirements sufficiently to give you an authoritative answer.  You should do the calculations yourself, it's a pretty simple decision.  First figure out how much concurrent data bandwidth you need.  If one memory controller meets your needs, you shouldn't attempt to use two -- this will add considerable complexity to your design.
- Bob
SIGNATURE:
Summary:
