Spartan 3A - Strange Voltage Levels on CCLK
I’m able to successfully load my bitsteam from SPI flash (M25P16) with the FPGA in SPI master mode (M2=0, M1=0, M0=1). But I notice strange logic levels on the configuration clock (CCLK). While it’s loading, logic low only goes down to 0.5V but logic high is fine at 3.3V. Before and after loading, CCLK is a static 1.6V and actively being driven so this can’t be due to pullup/pulldown/keeper.
The “Spartan-3 Generation Configuration User Guide” doesn’t mention the behavior I’m seeing. It also says CCLK becomes a user configurable pin (which I don’t use) after DONE so it should float after initialization. I double checked my board layout and nothing else drives CCLK. I even checked this on an old Digilent Spartan 3A Starter Kit eval board and it does the same thing. What is going on?
Re: Spartan 3A - Strange Voltage Levels on CCLK
I found the problem. The hardware layout added 100 ohm pull up AND pull down to the FPGA CCLK signal. This explains the 1.6 volts (half 3.3V). The hardware designer did this to "terminate" CCK at 50 ohms (see figure 4 in this document). Yikes! Guess where he got this idea -- the Digilent Spartan 3A eval board does the same thing! We'll have to evaluate if this is proper (logic low is questionable) but at least I now know what is causing the "Strange Voltage Levels".
r,
Sounds like crosstalk to the pin from some other trace or pin adjacent.  To check, you could put a 1K to ground on CCLK -- if the signal is attenuated, then it is crosstalk, and of no concern.
Austin Lesea
Principal Engineer
Xilinx San Jose
r,
Even changing the resistors to 220, or 470 ohms each might terminate well enough.  I would look at the signal integrity with no resistors, and with 470 ohms.  It does not have to be a perfect match to work reliably.
The other choice is to remove both, and 'teepee' a series 100 ohm and 0.01uF chip cap to terminate AC coupled (which is fine for a clock).  While not pretty, it is an acceptable fix until a board respin (can be done such that its quality is acceptable during inspection).
Austin Lesea
Principal Engineer
Xilinx San Jose
