Newbie koloss90
Spartan 3E Multi-Output Single Input problem
a few werk ago  i bought a spartan 3e dev Board from waveshare with Xilinx ISE12.2.
Since then i realized a few Projects (only in Software Not send the stream to
the Board). But for the newest project i am trying to connect 7 latches with an adder through a Common Bus.
And i get a few error msgs saying: Too Many Outputs connected to One Input.
So i tried tri-state buffers. Nothing works. I Can Provide .sch-file and error-file (edited) if needed.
thanks
M.
Voyager
Voyager
Re: Spartan 3E Multi-Output Single Input problem
Hey @koloss90
That would be helpful!
Best,
Herbert
-------------- Yes, I do this for fun!
Newbie koloss90
here they come
Voyager
Voyager
Now this is much clearer ...
ERROR:Xst:528 - Multi-source in Unit <CPU_2> on signal <XLXN_19<7>>; this signal is connected to multiple drivers.
Tells you that you are trying to drivea signal with more than one input.
I.e. you are basically creating a short circuit of several outputs on a single wire (which is not a good idea :).
You need/want to combine those different outputs in some way, for example through a gate (AND, OR, etc).
Hope that helps,
Herbert
Newbie koloss90
i'm sorry, but this doesn't help me in any way. For that reason Tri-State buffers were invented. But if this is the way those problems are solved in fpga designs, i'm happy with that. Thanks a lot.
M.
