Newbie gv260ea
Spartan 3E starter board DAC problem
Hi For couple of days i've been trying to implement the spi interface i have simulated it which shows that it works and ive checked with the scope aswell. All the proper commands are sent the correct polarity etc. but the dac still doesnt output anything. I'm triying to send CMD = 0x3 ADDR = 0x0 DATA = 0xFF0. I've inversed it in my code so that it fits the msb first rule
SCK is generated ok it's at 4.127MHZ. CS line is pulled low when the data transmisson starts. Then pulled back high. To sum it all up evrything with the spi bus works perfectly but the DAC(LTC2624) doesnt work. Nothing is outputed
Here is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity DAC is
	port
			CLK : in STD_LOGIC;
			SCK : out STD_LOGIC := '0';
			MOSI : out STD_LOGIC := '0';
			CSDAC : out STD_LOGIC := '1';
			SPI_SS_B : out STD_LOGIC;
			AMP_CS : out STD_LOGIC;
			AD_CONV : out STD_LOGIC;
			SF_CE0 : out STD_LOGIC;
			FPGA_INIT_B : out STD_LOGIC;
			DEBUG : out STD_LOGIC := '1'
end DAC;
architecture Behavioral of DAC is
Signal Counter : Integer range 0 to 6 := 0;
Signal Counter2 : Integer range 0 to 33 := 0;
Signal CurrentBit : Integer range 0 to 33 := 0;
Signal Fixed : STD_LOGIC := '0';
Signal DataSent : STD_LOGIC := '0';
Constant Data : STD_LOGIC_VECTOR(31 downto 0) := X"0FFF0C00";
Signal Slope_last : STD_LOGIC := '0';
Signal Slope : STD_LOGIC := '0';
begin
WriteDac : process(CLK)
begin
	if rising_edge(CLK) then
		if Counter = 5 then
			Counter <= 0;
			Slope_last <= Slope;
			Slope <= not(Slope);
		   if Slope_last = '0' and Slope = '1' then
				if Fixed = '1' then
					if DataSent = '0' then
						if CurrentBit <= 31 then
							CSDAC <= '0';
							DEBUG <= '0';
							MOSI <= Data(CurrentBit);
							CurrentBit <= CurrentBit +1;
						 else
							MOSI <= '0';
							CSDAC <= '1';
							DEBUG <= '1';
							DataSent <= '1';
						end if;
					end if;
				else
				  if Counter2 <= 31 then
						CSDAC <= '1';
						DEBUG <= '1';
						Counter2 <= Counter2 + 1;
				  else
						Fixed <= '1';
						MOSI <= '0';
				  end if;
				end if;
			end if;
		else
			Counter <= Counter + 1;
		end if;
	end if;
end process;
SCK <= SLOPE;
SPI_SS_B <= '1';
AMP_CS <= '1';
AD_CONV <= '0';
SF_CE0 <= '1';
FPGA_INIT_B <= '0';
end Behavioral;
Historian
Historian
Re: Spartan 3E starter board DAC problem
Did you simulate the design?
Why are you using a counter to index the bits in the outgoing data register instead of just loading a shift register?
Historian
Historian
Are the bits going out in the right order?
