vohaid
Spartan 3an Bootloader Question
Hi, I am using a spartan 3an and was wondering if it is possible to store the configuration file in ISF and boot the user application code in external spi flash?  On startup, I want the FPGA to run a small bootloader in ISF and grab the application code in external spi flash and copy it to RAM.  Can this be done since the ISF is already using spi?  Also, I cant perform indirect programming to external spi via iMPACT because of ISF.
HV
horkel
As I can understand, you will need to programme external SPI Flash connected to Spartan-3AN using IMPACT. There is one problem, IMPACT does not (now?) support indirect programming of external SPI Flash for Spartan-3AN. How to overcome the problem is written here:
http://forums.xilinx.com/t5/Design-Tools-Others/Impact-12-4-adding-SPI-for-indirect-programming/m-p/123770#M1794
I hope this helps you.
Milan
eteam00
Instructor
Instructor
Almost 2 years too late, I'm afraid.
- Bob Elkind
SIGNATURE:
Summary:
