Newbie yuti
Spartan 6 Configuration
Hello Team, I plan to use Spartan 6 FPGA (XA6SLX100). I would want to use indirect programming for programming the configuration device. Which configuration would be better to use. I have a DDR in my design. SPI (would it be fast enough) would it be possible for indirect programming? For parallel ( would it be indirect programmable)? Also which user guide would help in figuring out the size of configuration IC that I can use?
Community Manager
Community Manager
Re: Spartan 6 Configuration
You can refer to https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/pim_r_supported_spi_bpi_proms.htm for the list of supported flash families both serial and parallel.
Usually BPI would be faster than SPI.
HI @yuti,
Spartan-6 FPGAs can configure directly from commodity SPI serial flash and parallel NOR flash memories.  and  regrading the indirect programming see XAPP973, Indirect Programming of BPI PROMs with Virtex-5 FPGAs, and XAPP974, Indirect Programming of SPI Serial Flash PROMs with Spartan-3A FPGAs and see the XAPP586 Using SPI Flash with 7 Series FPGAs, then you can have brief ideal about the difference , based on your application need (configuration time )you have choose the configuration mode.
Thanks & Regrads
S.chandra sekhar
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Hi @yuti
Check the configuration user guide for complete details of the supported configuration modes and related guidelines.
http://www.xilinx.com/support/documentation/user_guides/ug380.pdf
Thanks,Vijay
following application note for spi configuration might help you
https://www.xilinx.com/support/documentation/application_notes/xapp951.pdf
