Visitor guyeschemann
Spartan-6 ISERDES2 Reset
What's the purpose of the ISERDES2 RST input? Can I safely tie it to zero? Does it have an influence on the bitslip mechanism?
-- Guy.
Re: Spartan-6 ISERDES2 Reset
The purpose of the reset is to put all of the registers into a known state, especially the bitslip.  You must reset the ISERDES2 before you use it.
Thanks for your help. Assuming that I've got two cascaded ISERDES2 (master and slave), which one should be reset? Same question for the bitslip signal: should it be applied to the master, slave, or both ISERDES2?
Many thanks,
-- Guy.
Hi Guy,
Tie the resets together and do the same for the bitslip.  You can see examples of using these in XAPP 1064 (see below)and there is a Wizard in Coregen that can help set it up as well.
http://www.xilinx.com/support/documentation/application_notes/xapp1064.pdf
-Roy
Instructor
Instructor
Coregen for ISERDES2?
roym wrote:
... Tie the resets together and do the same for the bitslip.  You can see examples of using these in XAPP 1064 (see below)and there is a Wizard in Coregen that can help set it up as well.
-Roy
Roy,
Maybe I'm misinterpreting your comments, but I see no sign of a Coregen wizard for ISERDES2 (S6) in ISE12.2.  Nor is there any reference to CoreGen in the XAPP1064 .PDF.  If there is such a wizard, please correct me (and a pointer would be helpful as well).
- Bob Elkind
SIGNATURE:
Summary:
Re: Coregen for ISERDES2?
CoreGen = Core Generator . Search "Core Generator" in xapp1064 and you will find several reference to it. Please take a look at attached snapshot to see where you can find the SelectIO wizard in CoreGen.
On WIndows, you can invoke CoreGen by Start->Programs->Xilinx ISE Design Suite 12.2->ISE Design Tools->Tools->Core Generator
On Linux, run "coregen" from a terminal.
Roy,
- Bob Elkind
Cheers,
Jim
Instructor
Instructor
Thanks for the pointers, Jim.
The SelectIO Wizard foe generating ISERDES2 instances is... interesting.   In some ways it is supplemental to UG381, UG382, and the XAPP1064 docs.
- Bob Elkind
SIGNATURE:
Summary:
