Spartan-6 LX150T development kit problem with schematic
This is in regards to an avnet aes-s6dev-lx150t-g. The schematics for this board show (https://www.em.avnet.com/Support%20And%20Downloads/xlx_s6_lx150t_dev-sch-revd090810.pdf) FPGA connections to the FMC connectors. FMC2 connector pin D8 and D9 pair are connected to 2 different FPGA pin pairs resulting in the two FPGA pins being shorted as follows.
FMC2 Pin Number             Net Name                                          FPGA Pin
D8                                         FMC2_LA01_CC_P                          V11, V12 (shorted)
D9                                         FMC2_La01_CC_N                         W12, V10 (shorted)
In addition its noted that the FMC connection uses 2 pins on the FPGA but, FMC pins C22 and C23 go to bank 1 whereas all the other FMC connectors go to bank 2. Is it possible that one of the shorted pin pairs should actually be used instead of this bank 1 conneciton.
Please confirm ASAP.
Re: Spartan-6 LX150T development kit problem with schematic
It is Avnet make board. So I would recommend you here is to talk to your Avnet FAE he would be a right person to guide you on this. You can find contact details of them from the following link http://www.xilinx.com/company/sales/ww_disti.htm (That link can guide to http://www.xilinx.com/company/contact/auth-disti-table.htm)
