trovohocho
Spartan-6 input clock
I have searched for what kind of differential signal clock is needed as input in Spartan-6, and I havn't seen anything, I suppouse that the Spartan-6 needs LVDS signal clock, is it possible use a LVPECL signal clock??
eteam00
Professor
Professor
For clock input(s), you can use any of the IOSTANDARD signal levels which appear in the Spartan-6 datasheet.  Some IOSTANDARD input options place restrictions on VCCO and VCCAUX voltage supplies.  These restrictions are described in the Spartan-6 datasheet (DS162).
There is no requirement for differential signaling for clock inputs.  Using single-ended input clocks is a common practice.  You will have to determine whether or not differential input clock is required for your applications.
-- Bob Elkind
SIGNATURE:
Summary:
