Spartan6 GTP Use mode RX Elastic Buffer Bypass
Hi!
In the datasheet UG386 "Spartan-6 FPGA GTP Transceivers" on page 133 is written "An advanced feature of Spartan-6 FPGA GTP transceivers that is NOT RECOMMENDED for NORMAL operation is bypassing of the RX elastic buffer."
Is it possible to correctly use the GTP in this mode?
Re: Spartan6 GTP Use mode RX Elastic Buffer Bypass
Yes. But you will need to take care of the phase alignment circuit implementation and the re-initialization requirement for different scenarios as mentioned in page 138
In xc6slx45t-fgg484, I coregen 4lane GTP in bypass rx buf and tx buf,  the example implement is ERROR, not no why? I change nothing.
