Visitor jbeesoniq1
Spartan6 IODELAY2 Calibration
In SP6 UG381 in the IODELAY2 section, subsection "Calibration Example" it states the following:
"In this example, the delay taps have an average value of 80 ps. An I/O clock of 250 MHz
(4,000 ps) is applied to IODELAY2. When the calibrate command is issued, a value of
4,000 / 80 = 50 is returned internally. If the input delay has been programmed to be
VARIABLE_FROM_HALF_MAX, then, following a reset command, the input delay value
is set to 25 taps, approximately ½ the input clock period."
Where did the avg of 80ps per tap come from?  According to the SP6 datasheet (ds162) Table 38 (IO Delay switiching charateristics) the average tap delay is more like 53ps at its highest, rather than 80ps.
Thanks!
Visitor jbeesoniq1
Re: Spartan6 IODELAY2 Calibration
Teacher eteam00
Spartan-6 silicon was updated earlier this year, specifically to clean up the IODELAY blocks.  The current  version of DS162 reflects the latest and greatest IODELAY characterisation data.  The information you describe is in Table 39, which was updated in DS162 Version 1.3
The current version of UG381 (v1.4) pre-dates the IODELAY block revisions.  The Calibration Example description in UG381 is intended as a description of the IODELAY block calibration process, and is not meant to supercede the datasheet (DS162).  The datasheet numbers must be given precedence.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor jbeesoniq1
Hi Bob,
Thank you for the clarification!  I have a mix of silicon from last year and this year, it sounds like they will operate differently?
I posted a separate question about not performing calibration for general async deskew for margin improvement(http://forums.xilinx.com/t5/Spartan-Family-FPGAs/Skipping-Spartan6-IODELAY2-Cal/td-p/165848)... perhaps given this answer it is related.
Teacher eteam00
Possibly, depending on wafer lots.  Answer Record 41083 speaks to this question.
-- Bob Elkind
SIGNATURE:
Summary:
Visitor jbeesoniq1
