Spartan6 MIG compatibility with ISSI DDR
Have anyone had successful interfacing ISSI DDR 3 with Spartan 6 ? I know I can use custom part in MIG-core gen and the timings are well within the base range listed. Just wanted to hear from users who were successful or is there any special attention needed for using the DDR not listed in the Xilinx supported memory.
Re: Spartan6 MIG compatibility with ISSI DDR
The parts not listed in MIG GUI drop down are not hardware evaluated by Xilinx.
But I have seen few customers used ISSI parts successfully.
You just need to take care that you have given all the timing parameters of ISSI part while custom part generation.
Make sure behavioural simulation is successfull and and then go for  HW.
Hope this helps
Vanitha
Hope this helps
Vanitha
