Visitor diego.gs
Spartan6 UG380 v2.10: resistor values in W!
Hi, I just downloaded Spartan6 UG380 v2.10 and I noticed that resistor values in figure 2-12 (page 42 of PDF) are in Watts, but they should really be in Ohms!
In revision v2.5, which I found in our company archives, this error was not present.
This error may be present in other figures, I didn't check.
Re: I don't want to live with this annoyance. Not for a Xilin...
Teacher drjohnsmith
Re: Spartan6 UG380 v2.10: resistor values in W!
Its an OLD OLD Problem,
Type setters have problems with the Latin Ohms,
and print it as W....
Don't ask me why, but you will see it every where around the world,
   I just live with its annoyance.
Scholar u4223374
Good catch! It does seem unlikely that Xilinx has installed 4.7kW resistors to pull-up INIT_B and PROGRAM_B.
My guess is that someone's updated this to the latest formatting, and in the process they've gone from Ω (capital omega, symbol for ohms) to ω (lower-case omega) to w (which looks a lot like lower-case omega) to W (when they converted units back to capitals).
What!  You mean I don't need to find board space for a 4.7 kW resistor?
Visitor diego.gs
Not for a Xilinx device.
I would like to report this to someone at Xilinx, do someone know where to send such a report? TI has a form for reporting documentation issues...
Visitor diego.gs
Done. Thank you !
Done.
Thank you @kkn !
I hope a v2.11 with this problem fixed will be created soon
