eneserdin
States of user I/O's for an unconfigured FPGA
I am interested in in-system programming of an Spartan 3 FPGA via uBlaze. Do you know the states of the user I/O's of an unconfigured FPGA? Since I will implement a JTAG connection (program loader, prom loader etc.) through FPGA pins which is multiplexed with Platform Cable. However, as the application note says (XAPP482) the TDO pin is not multiplexed and connected directly both to the uBlaze and platform cable connector. I wonder if that TDO of uBlaze creates trouble for me for an unconfigured FPGA.
Thanks in advance.
eteam00
Instructor
Instructor
Typically high impedance or weak pullup to VCCO, depending on state of HSWAPEN pin.
JTAG and configuration pins are not "user I/Os" when unconfigured.
You understand, of course, that the uBlaze must be running in a second, configured FPGA.  There is no such thing as a uBlaze running in an unconfigured FPGA.
- Bob Elkind
SIGNATURE:
Summary:
eteam00
Instructor
Instructor
- Bob Elkind
SIGNATURE:
Summary:
eneserdin
In the datasheet, it was saying that a high level HSWAP_EN makes the user I/Os "float" !?. That made everything clear, thanks!
For the other part I think I have to write things more explanatory. I don't ask the states of the user I/Os while configuration. Think that, there is a PROM and an FPGA on the JTAG chain. When you "first time" power up the board, after the board came from production, FPGA is not configured so does the PROM, and I want to load a PROM file into the PROM, that is the FPGA is bypassed in the Impact S/W. In that case the FPGA is not (being) configured however the JTAG chain is working. In that case the user I/O (namely TDO) that I duplicated on an FPGA pin can make things bad or not? (one of the duplicated net goes to Jtag connector and the other goes to user i/o)
If there is something wrong please let me know.
eteam00
Instructor
Instructor
Are you being sarcastic?  In the hardware engineering world the term "floating input" is well understood.  A "floating" pin or net means that it is not being driven - actively or passively.  If the pin or net is connected to a logic gate input, its logic state is indeterminate.
Your description is still unclear.
If you wish to use a microBlaze to directly program an FPGA, the microBlaze must be resident in an FPGA other than the one which is being programmed.
If you wish to use a microBlaze to program a PROM, to load a new FPGA configuration file, this is quite straightforward to implement.  In this manner, a microBlaze can be used to indirectly re-program the same FPGA in which it resides.
  • An unconfigured FPGA can be programmed via JTAG (e.g. IMPACT).
  • An unconfigured FPGA can be used to indirectly program a PROM via JTAG (e.g. IMPACT).
  • If the PROM is a JTAG PROM (e.g.  Xilinx Platform Flash), JTAG (including IMPACT) can be used to directly program the PROM.
  • A microBlaze implementing a JTAG controller can be used to directly program a JTAG PROM (e.g. Platform Flash)
  • A configured FPGA may be designed to disable its JTAG port, perhaps to use the JTAG pins for user IO.  In such cases, the configured FPGA may NOT be programmed via JTAG.
Does this answer your question?
- Bob Elkind
SIGNATURE:
Summary:
eneserdin
Of course I am not sarcastic. I am only a young engineer whose mother tongue is not English. Additionally in the datasheet it does not say floating input it only says float. Anyway, I do not want to annoy you. My respect to you, the expert designers. Thank you for your invaluable comments.
Rearrangement of the question, forget about everything. What is the state of the I/O's of an FPGA when you just power it up (No PROM, no JTAG).
eteam00
Instructor
Instructor
Already asked and answered:
- Bob Elkind
SIGNATURE:
Summary:
bassman59
Historian
Historian
This information is IN THE FINE USER GUIDE. Read it.
gregmeredith
Just to be clear you can pick between High-Z or pullup by tying the HSWAP pin up or down, and that is right that this is further documented in the config user guide.
