TDC for Spartan 6 Evaluation Board
Hey guys, I wanted to know if the Spartan 6 Evaluation Board contains a built in TDC, if not
-can I integrate this GPX2 IC: https://www.digikey.com/product-detail/en/ams/TDC-GPX2/TDC-GPX2-ND/6569301
with the Spartan 6 Eva Board through a breakout board?
-If not what is the best TDC I can integrate with this board?
If anyone has prior experience with this your help will be really appreciated.
Voyager
Voyager
Re: TDC for Spartan 6 Evaluation Board
Hey @darshanvenkat,
Hey guys, I wanted to know if the Spartan 6 Evaluation Board contains a built in TDC ...
No, as far as I know it doesn't, unless it is hidden pretty well :)
can I integrate this GPX2 IC with the Spartan 6 Eva Board through a breakout board?
Yes, I don't see why you can't, there are enough IOs on the board to connect to.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Scholar austin
Time to digital converter?
That is 'just' a verilog or VHDL design you would implement to be synthesized, placed, and routed on our device.
Austin Lesea
Principal Engineer
Xilinx San Jose
Voyager
Voyager
Hey @darshanvenkat,
Hope this helps,
Herbert
Voyager
Voyager
@austin,
I don't think you can get 10ps resolution on the Spartan 6, but maybe you know better ...
Best,
Herbert
I've seen some very nice work implanted by engineers needing to implement a lot of TDC in a single device with picosecond resolution. They used the propagation delay through carry chains to obtain finer resolution than the clock period. These schemes required 'calibration cycles' to maintain accuracy. Interestingly, their analysis also revealed the significance of power supplies with linear (analogue) supplies resulting in greater timing accuracy than switching supplies. It's kind of obvious why but not a factor that immediately springs to mind (or at least my mind) until someone points it out and shows you experimental results.
Ken Chapman
Principal Engineer, Xilinx UK
Hey thanks for the answer, but will I want to integrate an external TDC to have less than 10ps resolution for very high speed process. So is it possible to connect GPX2 TDC?
Thanks man!
Voyager
Voyager
@chapman:
You don't happen to have a link to a paper at hand or even better some repository with code to look at?
Anyway, thanks a lot for the input, didn't know this was actually used.
Best,
Herbert
Hey thanks for the answer, but I want to integrate an external TDC to have less than 10ps resolution for very high speed process. So is it possible to connect GPX2 TDC?
@hpoetzl sorry for messing the thread, im new here the previous question is for you:
Voyager
Voyager
@darshanvenkat:
sorry for messing the thread, im new here ...
No problem, welcome to the forum!
As I wrote, I don't see why you can't connect it to the devkit.
Best,
Herbert
@hpoetzl thanks man! I will research on connecting it!
Voyager
Voyager
You're welcome!
All the best,
Herbert
