sharpless512
Text on second line LCD
Hi ,
I have bought the Spartan 3E starter kit because I want to learn VHDL.
I'm trying to get text on the lcd, so far it worked. But I don't know how to put text on the second line.
Is there a special code for it?
I have studied this pdf file: http://www.cosmiac.org/pdfs/09Tutorial6.pdf
UCF file:
NET "clk" LOC = "C9";
NET "reset" LOC = "K17";
NET "SF_CE0" LOC = "D16" | IOSTANDARD = LVCMOS33 | SLEW = SLOW ;
NET "LCD_E" LOC = "M18" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "LCD_RS" LOC = "L18" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "LCD_RW" LOC = "L17" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "SF_D<0>" LOC = "R15" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "SF_D<1>" LOC = "R16" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "SF_D<2>" LOC = "P17" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "SF_D<3>" LOC = "M15" | IOSTANDARD = LVCMOS33 | DRIVE = 4 | SLEW = SLOW ;
NET "led[0]" LOC = F12;
NET "led[1]" LOC = E12;
NET "led[2]" LOC = E11;
NET "led[3]" LOC = F11;
NET "led[4]" LOC = C11;
NET "led[5]" LOC = D11;
NET "led[6]" LOC = E9;
NET "led[7]" LOC = F9;
Can you help me?
Many thanks.
bwiec
There is a pointer that you can change manually with a Set DD RAM Address command. Please see the Spartan 3e Users Guide:
"Set DD RAM Address
Set the initial DD RAM address.
After this command, all subsequent read or write operations to the display are to or from
DD RAM. The addresses for displayed characters appear in Figure 5-3.
Execution Time: 40 μs"
See Figure 5-3 (UG230) for addressing.
www.xilinx.com
sharpless512
thank you for your fast reply!
But how can you put that in code, please help
bwiec
Just add it to your main state machine (looking at the tutorial you are looking at). The timing should be the same as a write command, if I recall correctly.
www.xilinx.com
eteam00
Professor
Professor
This post might be helpful.
-- Bob Elkind
SIGNATURE:
Summary:
sharpless512
So what code (in bits) do I need to send?
Do I need to send that code after each letter? Is that the same code as the letters but other bits?
bwiec
I believe (again, from memory) that the pointer gets incremented (by default) every time you write to it. But notice the address map does not wrap directly... there are some extra addresses on the top line that do not correspond to the display.
The bits you need to send depends on what address you want to point to. See TABLE 5-3 for the address mapping and control signals.
www.xilinx.com
sharpless512
0x40 is for next line on the lcd, but do I need to write 0100 0000 in the cur_state of the program after you want to write on the second line?
How do you update the pointer?
still many thanks for your replies!
