Visitor hassaniqbal
Too many comps of type "PLL_ADV" found to fit this device
I am using Atlys Spartan 6 FPGA development board. I have to combine XAPP495 with external memory interface. When I combine the DDR2 interface example code available here with XAPP495, I get the following error:
Too many comps of type "PLL_ADV" found to fit this device.
The design is too large to fit the device.
I am unable to find any "PLL_ADV" in XAPP495 verilog files. Please guide how should I remove this error. I have consulted Hierarchical Design Methodology Guide but cannot find to remove the error. Thank you.
Tags (3)
Re: Too many comps of type "PLL_ADV" found to fit this device
Put simply, you are using more PLLs than the available number in the device. I won't do your homework, but both designs are likely using some PLLs and that just amount to too many of them.
YL
Historian
Historian
The PLL_ADV cell is used whenever a PLL is instantiated, whether the actual instantiation is of a PLL_ADV or a PLL_BASE.
So if the number of PLL_ADV + PLL_BASE instantiations (including generated loops) exceeds the number of PLL_ADV cells on the die, which for the LX45 is 4, then you will get this error.
Avrum
Please check whether any of the below link documents information helpful to debug the issue?
https://www.xilinx.com/support/answers/39627.html
https://www.xilinx.com/support/answers/44714.html
https://www.xilinx.com/support/answers/61934.html
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/spartan6_hdl.pdf
