Trouble with PLL configuration
Hi, I am working with the Opal Kelly 3010s1500. I trying to configure the PLL through matlab using the api. Below is the following code that I am using in Matlab:
ref = calllib('okFrontPanel', 'okPLL22393_SetReference', xem.ptr, 200*10^6);
calllib('okFrontPanel', 'okPLL22393_SetPLLParameters', xem.ptr, 0, 6, 2, true);
calllib('okFrontPanel','okPLL22393_SetOutputSource',xem.ptr, 1, 'ok_ClkSrc22393_PLL0_0')
calllib('okFrontPanel','okPLL22393_SetOutputDivider',xem.ptr, 1, 2)
calllib('okFrontPanel','okPLL22393_SetOutputEnable',xem.ptr,1,true)
calllib('okFrontPanel', 'okFrontPanel_SetPLL22393Configuration', xem.ptr, 1)
out_freq = calllib('okFrontPanel', 'okPLL22393_GetOutputFrequency',xem.ptr,1)
This runs without errors and I get the expected value for out_freq.
However, I do not understand which sysClk on the xem3010 is being selected, I believe that I am selecting sysClk2 but when I attach the associated pin to an oscilloscope, I do not see the clock signal. (I have linked this internal pin to an external pin in vhdl.)  Could someone let me know if my thinking is correct or how I can send the PLL configuration to a clock pin.
Also I know that I can do this through the frontpanel, however I need to set the PLL using the api.
Thanks in advance.
Adam G.
Re: Trouble with PLL configuration
How does this relate to Xilinx devices?
