UCF file and pin planning issue
I am trying to learn chipscope and usinfg the tutorial (File attached) explained with Spartan 6 SP601.
I am trying to implement the design given on Spartan 6 xc6slx100.. So the "ucf " file need to be edited..
I did so in PLan ahead.. but I am getting following error
ERROR:Place:1118 - The I/O components "CLK_P" and "CLK_N" are the P- and N-sides
of a differential I/O pair. The component "CLK_P" needs to be placed in a
IOBM site and component "CLK_N" in the adjacent IOBS site within the same I/O
tile. The following issue has been detected:
All of the logic associated with this structure is locked and the relative
placement of the logic violates the structure. The problem was found between
the relative placement of IOB CLK_P at site PAD43 and IOB CLK_N at site
PAD173.
It is possible to allow location constraints to override this rule by
setting the environment variable XIL_PAR_ALLOW_LVDS_LOC_OVERRIDE.
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
NET "clk" PERIOD = 5 ns;
NET "CLK_P" LOC = B10;
NET "CLK_N" LOC = H21;
NET "GPIO_BUTTONS[0]" LOC = A19;
NET "GPIO_BUTTONS[1]" LOC = G26;
NET "LEDS_n[0]" LOC = AC22;
NET "LEDS_n[1]" LOC = AC24;
NET "LEDS_n[2]" LOC = AE22;
NET "LEDS_n[3]" LOC = AE23;
NET "GPIO_BUTTONS[0]" LOC = C8;
NET "GPIO_BUTTONS[1]" LOC = D8;
NET "LEDS_n[0]" LOC = A8;
NET "LEDS_n[1]" LOC = A7;
NET "LEDS_n[2]" LOC = A6;
NET "LEDS_n[3]" LOC = A5;
Hi @gsarode
Can you tell us the exact FPGA part you are using?
From the error it looks like you have assigned p-type package pin to n side of differential port (CLK_N) and vice-versa. Check the package files at http://www.xilinx.com/support/package-pinout-files/spartan-6-pkgs.html and ensure that you are using p-type package pin to p side of differential port.
Deepika.
Hi @gsarode,
Which package and device are you using?
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
Hi @gsarode
Are the above posts helpful?
Deepika.
