Advisor joelby
Advisor
Re: UDP IP stack on a Spartan-6
The Ethernet checksum should be generated by the MAC (I forget exactly where and don't have the code in front of me).
Did the unmodified example work correctly?
Observer kruljcina
Hi Joelby,
sorry I have just realized that I have modified your code to work with RGMII standard of my KSZ9021. By MAC
you are referring to the 88E1111 chip?
Teacher drjohnsmith
re checksum.
The TCP / IP header checksum , not in the macs as far as the ones I have seen .
easy to impliment in the code though, only have to do a ones compliment addition,
Advisor joelby
Advisor
Ah, if you've modified the MAC, then I have no idea what's wrong! ;-) The MAC is everything under the "simple_gemac" directory. The 88E1111 and the KSZ9021 are both PHYs.
In the original code, CRCs are calculated during transmit in simple_gemac_tx.v:
crc crc(.clk(tx_clk), .reset(reset), .clear(clear_crc),
.data(txd_pre), .calc(calc_crc), .crc_out(crc_out));
and output to the wire in this bit:
	case(tx_state)
	  TX_CRC_0 :
	    GMII_TXD <= crc_out[31:24];
	  TX_CRC_1 :
	    GMII_TXD <= crc_out[23:16];
	  TX_CRC_2 :
	    GMII_TXD <= crc_out[15:8];
	  TX_CRC_3 :
	    GMII_TXD <= crc_out[7:0];
 Check your simulation to see if these states are being reached correctly.
Observer kruljcina
you are right I have bypassed some code and crc
was probably excluded.
Sorry for false alarm.
Visitor lama_prog
Hello! Anybody happen to have a pin configuration file (*...
Hello!
Anybody happen to have a pin configuration file (*. ucf) to run this project on the Xilinx SP605 evaluation kit?
I would really appreciate if you share!
Sincerely.
do you know how can i confugure pins of ml605 virtex  board to spartan 6 board.I am working on udp ip stack layer project.
Visitor lama_prog
Hello!
After a little editing *.ucf file and PLL core settigs i can execute this UDP stack on SP605 evaluation kit.
Iperf utility show 550-570 Mbps bandwidth after a change package send mode (from manual to forced - in top level module i change packet_sender(...  .start(sw_send_packet),  ....); to .start(1'b1)).  But wireshark displayed input datagrams with [ETHERNET FRAME CHECK SEQUENCE INCORRECT] mark. Please, tell me, what i am doing wrong?
I also tried receive UDP datagrams (host send broadcast packet), but packet_receiver FSM always in state 0... There are any thoughts about why?
Best regards
Advisor joelby
Advisor
Using my example code? You'll need to use unicast UDP using the correct destination IP and port. I used netcat for this, using the IP address hard-coded in the code. Sorry it's not better documented! :(
Visitor lama_prog
Hi, joelby!
Thanks for your reply.
At first i used QUdpSocket class in Qt 4.8.5 framework to send datagrams to my developer board, but i have some problems (wireshark not shown outbox datagrams - probably because it was not possible to get the MAC address of the recipient - it was not in ARP table and I think, in the used stack is not implemented response to ARP request to the MAC address of the device) and i can send only broadcast datagrams.
After your reply i used Colasoft Packet Builder 1.0 [http://www.colasoft.com/packet_builder/] to send packet. After learning your's testbench tb_packet_receiver_gemac.v i found mistake in my code - i forgot change ucast_addr! After i change parameters for wb_reg_ucast_h and wb_reg_ucast_l  in module simple_gemac_wb i saw the data sent in PuTTY utility which connected to SP605 in serial mode.
Again thanks for your reply :)
With best regards!
Visitor lama_prog
Understood of QUdpSocket in Qt 4.8.5. Problem was the proxy settings on the host.
Сontinue to explore this UDP/IP stack.
hi,I am using your udp_ip code,but I don,t know how to send data to atlys,use linux,s socket or others,how did you do it ?
Advisor joelby
Advisor
For debugging or simple applications, the 'netcat' program is great for sending UDP packets.
For anything more complex or robust, it's probably best to write a program in your language of choice.
thank for you reply,I attemp to use netcat,My linux installed in vmware,my linux net ipaddr is 192.168.2.112,hardware is 000c_29e9_cf6b,becaue my board is atlys,so I just chang your code in the packet_sender as follows:
 parameter SRC_PORT = 16'h1234;
 parameter DST_PORT = 16'h1234;
 parameter SRC_MAC = 48'h0037_ffff_3737;
 parameter DST_MAC = 48'h000c_29e9_cf6b;
 parameter DST_IP = 32'hc0a8_0170;
 parameter SRC_IP = 32'hc0a8_0171;
and then generate ethernet_test_top.bit,and download to my atlys board,connet atlys to my computer with net,and then
Type the command in the linux console as follows:
nc  -l  -p 1234
and then type some datas,I find it don,t work,and then I type the follows command:
nc 192.168.1.10 1234 -u -p 1234
and it,s also don,t work.I really don't know how to do it and where is wrong ,could you give me some advice?
thank you very much!
Advisor joelby
Advisor
Sorry it's not better document :( I've updated the web site with some more details.
The packet receiver process doesn't implement ARP, so you will need to set a static ARP entry:
arp -s 169.254.77.1 0037ffff3737
The IP address doesn't really matter (the packet receiver doesn't check it) but it will need to be something in the same subnet as your computer. The MAC address is set as a default in simple_gemac_wb.v.
Then nc -u 192.168.1.10 1234 should work! The port doesn't really matter either.
You should also be able to receive packets with nc -l -u but I can't remember if it sends anything very useful.. probably easiest to use Wireshark or tcpdump.
Visitor sameedsohail
Hi Joel & kruljcina,
I have bought AC701 Evaulation board and intend to send UDP packets from it via Ethernet. The PHY module it  uses is Marvell M88E1116r (i.e. RGMII ).
I want to know if any of you had success in implementing UDP transmission for RGMII so that i may be able to use the code for my purpose. I will appreciate any guidance on implementing this IP.
Sameed
Advisor joelby
Advisor
It's probably best if you start a new thread, rather than resurrecting an old one that relates to a different FPGA and different PHY!
I've never tried to use RGMII, but as long as you use a MAC that supports RGMII on a proven development board such as the AC701, you shouldn't have too much trouble. I'd probably recommend using the Xilinx TEMAC - my Spartan-6 sample code uses a MAC that only supports GMII at gigabit speeds. You might be able to use my code's UDP packet generator for inspiration and for the details of IP/UDP header generation, but be aware that the interface to the Xilinx MAC (and probably every other MAC) will be different.
Observer kruljcina
vau, that was long time ago. I did a very ugly hack
of the original code. I wasn't very efficient because I
managed to make only transmit to work, receive branch
had an error which I never got time to track down.
I based my GMII to RGMII converter on:
Rgmii adaptation module written by Ting Kao and Mary Low
I am not sure if it is ok to post their module but you can find it
easy on google.
best regards
Observer mkachar
My name is Mohith. I am a student who is interested in implementing UDP IPCore on kintex boards to support 10G ethernet. I have a beginners idea about fpga, verilog and IP stack; as i am new to this domain . Can you please teach me how to implement it from scratch.
Cheers
mohith
Observer mkachar
Mohith here again. I will be available on this email id for communication.
mktech.dis@gmail.com
cheers
Mohith
Advisor joelby
Advisor
Hi Mohith, I’m not sure if anyone here is a full-time teacher, but if you have any specific questions then feel free to ask (perhaps in a new thread)
