Unknown errors / warnings from ISE
I am trying to implement a shift register using the following construction:
 reg [15: 0] output_temp;
      repeat(16) begin
       output_temp[0] <= input_temp[0];          // save a bit
       output_temp <= output_temp << 1;       // next output bit
       input_temp <= input_temp >> 2;           // next input bit
     end
I get this error message for all 16 bits of output_temp:
WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch  <output_temp_15> has a constant value of 0 in block <rcvr>.
I can't find an explanation for this warning anywhere in the Xilinx web search or elsewhere. Any ideas on what to do next?
Xilinx has verilog examples for shift register inference in the XST User Guide:
Typically, you will get these types of warnings if the output of the a FF is not changing (it is a constant).  Have you looked at the logic connected to input_temp, is this changing?  Is something else upstream causing input_temp to get optimized to 0, so output_temp is also 0?
Thanks. I figured it had to be something like that. I'm still learning.
