lochoang
Using Spartan3 as Memory tester to test SPI memory
I am wondering if anyone has done it before. I am trying to use the Spartan3 as the master to write patterns serially to the flash memory then read the data back from the flash and compare with the original patterns to determine if the flash is good. I have been struggling to design the state machine.
Your advice is appreciated very much.
bassman59
Historian
Historian
What's not working?
