Visitor hsnzahid
VERILOG CODE HELP FOR SPARTAN 3
I need help in completing my semester project on verilog. I have made the code and it is compiling well but when I try to simulate, I get dozens of errors. I will greatly appreciate if someone can guide me with this coz I need to transfer the code on Spartan-3 fpga very soon. Here is the complete code I have mustered by now:
//MAIN stimulus file
Code:
module main();
reg CLK;
   reg   signed [31:0] WORD;
   wire   [7:0] PARABOLA;
   wire [7:0]   PHASE;
   wire SIGN;
   wire [6:0] TEMP;
   accumulator_phase pa(.word(WORD), .clk(CLK), .phase(PHASE), .sign(SIGN));
   parabola_gen pg(.phase(PHASE), .parabola(TEMP));
   format_converter fc(.signed_parabola(TEMP), .sign_ac(SIGN), .out_bits(PARABOLA));
   initial // Clock generator
      begin
         CLK = 1'b0;
         WORD = 32'b0;
         WORD[13] = 32'sh01000000;
      end
   always
      begin
         #20 CLK = 1'b1;
         #20 CLK = 1'b0;
         #20 CLK = 1'b1;
         #20 CLK = 1'b0;
      end
   initial
      $monitor($stime, CLK, WORD, PARABOLA);
endmodule
//PHASE ACCUMULATOR
Code:
module accumulator_phase(word, clk, phase, sign);
    input [31:0] word;
    input clk;
    output [7:0] phase;
    output sign;
   wire signed [31:0] word;
   wire clk;
   wire c1, c2, c3, c4, c5, c6, c7, c8;
   reg signed [31:0] x;
   reg signed [31:0] res;
   reg [7 : 0] phase;
   reg sign;
   initial
      begin
         phase <= 8'b0;
         x <= 32'b0;
         res <= 32'b0;
         sign <= 1'b0;
      end
   always @(posedge clk)
      begin
         phase <= res[30 : 23];
         sign <= res[31];
      end
   four_bit_adder fba1(res[3:0], c1, word[3:0], x[3:0], );
   four_bit_adder fba2(res[7:4], c2, word[7:4], x[7:4], c1);
   four_bit_adder fba3(res[11:8], c3, word[11:8], x[11:8], c2);
   four_bit_adder fba4(res[15:12], c4, word[15:12], x[15:12], c3);
   four_bit_adder fba5(res[19:16], c5, word[19:16], x[19:16], c4);
   four_bit_adder fba6(res[23:20], c6, word[23:20], x[23:20], c5);
   four_bit_adder fba7(res[27:24], c7, word[27:24], x[27:24], c6);
   four_bit_adder fba8(res[31:28], c8, word[31:28], x[31:28], c7);
endmodule
//FOUR BIT ADDER
Code:
module four_bit_adder(sum, carry_out, a, b, carry_in);
    output [3:0] sum;
    output carry_out;
    input [3:0] a;
    input [3:0] b;
    input carry_in;
  wire w1, w2, w3, w4, w5, w6, w7, w8, w9, w10, w11, w12;
  wire c1, c2, c3;
  xor (w1, a[0], b[0]),
    (sum[0], w1, carry_in);
  and (w2, a[0], b[0]),
    (w3, w1, carry_in);
  or (c1, w2, w3);
  xor (w4, a[1], b[1]),
    (sum[1], w4, c1);
  and (w5, a[1], b[1]),
    (w6, w4, c1);
  or (c2, w5, w6);
  xor (w7, a[2], b[2]),
    (sum[2], w7, c2);
  and (w8, a[2], b[2]),
    (w9, w7, c2);
  or (c3, w8, w9);
  xor (w10, a[3], b[3]),
    (sum[3], w10, c3);
  and (w11, a[3], b[3]),
    (w12, w10, c3);
  or (carry_out, w11, w12);
endmodule
//PARABOLA GENERATOR
Code:
module parabola_gen(phase, parabola);
    input [7:0] phase;
    output [6:0] parabola;
   wire [7:0] phase;
   reg [6:0] parabola;
   reg [15:0] result;
   reg signed [7:0] temp;
   two_comp tc(phase, temp);
   multiply mul(result,,phase,temp,1'b1);
   initial
      begin
         parabola <= 7'b0;
         result <= 16'b0;
      end
   always
         begin
            parabola = result[15 : 9];
         end
endmodule
//TWO's COMLEMENT
Code:
module two_comp(bits_in, bits_out);
   input [7:0] bits_in;
   output [7:0] bits_out;
   wire [7:0] bits_in;
   reg [7:0] bits_out;
   reg [7:0] bits_inv;
   reg [6:0] carry_tmp;
  initial
    bits_out = 8'b0;
   always
      bits_inv[7:0] = bits_in[7:0];
   fulladd addbit1 (bits_inv[0], 1, 0, bits_out[0], carry_tmp[0]);
   fulladd addbit2 (bits_inv[1], 0, carry_tmp[0], bits_out[1], carry_tmp[1]);
   fulladd addbit3 (bits_inv[2], 0, carry_tmp[1], bits_out[2], carry_tmp[2]);
   fulladd addbit4 (bits_inv[3], 0, carry_tmp[2], bits_out[3], carry_tmp[3]);
   fulladd addbit5 (bits_inv[4], 0, carry_tmp[3], bits_out[4], carry_tmp[4]);
   fulladd addbit6 (bits_inv[5], 0, carry_tmp[4], bits_out[5], carry_tmp[5]);
   fulladd addbit7 (bits_inv[6], 0, carry_tmp[5], bits_out[6], carry_tmp[6]);
   fulladd addbit8 (bits_inv[7], 0, carry_tmp[6], bits_out[7], carry_out);
endmodule
//FULL ADDER TO BE USED IN TWO's COMPLEMENT
Code:
module fulladd(a, b, carry_in, sum, carry_out);
    input a;
    input b;
    input carry_in;
    output sum;
    output carry_out;
    reg sum;
    reg carry_out;
   always @ (a or b or carry_in)
      begin
         case ({a,b,carry_in})
            3'b000:
               {sum,carry_out} = 3'b000;
            3'b010:
               {sum,carry_out} = 3'b010;
            3'b100:
            3'b110:
               {sum,carry_out} = 3'b100;
            3'b001:
            3'b011:
            3'b101:
            3'b111:
               {sum,carry_out} = 3'b001;
         endcase
end
endmodule
//MULTIPLIER
Code:
module multiply      (product,
         ready,
         multiplicand,
         multiplier,
         start);
   input [7:0]  multiplicand;
   input [7:0]  multiplier;
   input         start;
   output        product;
   output        ready;
   reg [31:0]    product;
   reg [4:0]     bit;
   wire          ready = !bit;
   reg           lostbit;
   initial bit = 0;
   always
     if( ready && start ) begin
        bit     = 16;
        product = { 16'd0, multiplier };
        lostbit = 0;
     end else if( bit ) begin:A
        case ( {product[0],lostbit} )
          2'b01: product[31:16] = product[31:16] + multiplicand;
          2'b10: product[31:16] = product[31:16] - multiplicand;
        endcase
        lostbit = product[0];
        product = { product[31], product[31:1] };
        bit     = bit - 1;
   end
endmodule
//FORMAT CONVERTER - FROM SIGNED TO UNSIGNED
Code:
module format_converter(signed_parabola, sign_ac, out_bits);
    input [6:0] signed_parabola;
    input sign_ac;
    output [7:0] out_bits;
   wire   sign_ac;
   wire   [6:0] signed_parabola;
   reg [7:0] temp;
   reg   [7:0]   out_bits;
   initial
      begin
         temp <= 8'b0;
         out_bits <= 8'b0;
      end
   always
      begin
         temp[7] <= sign_ac;
         temp[6:0] <= signed_parabola;
         out_bits <= $unsigned(temp);
      end
endmodule
Re: VERILOG CODE HELP FOR SPARTAN 3
You need to study Verilog some more - especially the always block and sensitivity lists.
To create a combinatorial block, the syntax is:
always @ (*)
   begin
   // your code in here
   end
 So your block should be:
always @ (*)
begin
temp[7] = sign_ac;
temp[6:0] = signed_parabola;
out_bits = $unsigned(temp);
end
This causes the always block to trigger when ever one of the input signals for the block changes.
Also note that I changed the non-blocking assignments (<=) to blocking assignments (=).  There several
good papers on the web that describe when to use blocking (combinatorial logic) or non-blocking (clocked logic).
I hope this helps!
John Providenza
Instructor
Instructor
You say you are getting "dozens of errors" when you simulate.  It would greatly improve your
chances of getting help if you let us know what these errors are.  Few of the Forum regulars
have time to take your code and try to reproduce the problems.  Many of us have seen a lot
of errors along the way and could give you useful insight if you post them.
Gabor
-- Gabor
Visitor hsnzahid
I have corrected the code very much by now, all those errors are gone. But now there is something new, a blue arrow would popup after the simulation runs and fails. It is a bookmark to the code line where simulation stopped. I have corrected some of these. Now I am stuck with this last one:
out_bits is an 8 bit register, which is the output of this module. This module coverts the input signed value to unsigned. Can you please tell me where I am wrong? The complete module is:
`timescale 1ns / 1ps ////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: // // Create Date: 01:00:49 01/07/2009 // Design Name: // Module Name: format_converter // Project Name: // Target Devices: // Tool versions: // Description: // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module format_converter(signed_parabola, sign_ac, out_bits); input [6:0] signed_parabola; input sign_ac; output [7:0] out_bits; //-------------------- wire sign_ac; wire [6:0] signed_parabola; reg [7:0] temp; reg [7:0] out_bits; initial begin temp <= 8'b0; out_bits <= 8'b0; end always begin temp[7] <= sign_ac; temp[6:0] <= signed_parabola; out_bits <= $unsigned(temp); end endmodule
always @ (*)
   begin
   end
always @ (*)
begin
temp[7] = sign_ac;
end
I hope this helps!
John Providenza
Visitor hsnzahid
Thank you very much sir, I understand the always function now. I am still learning to use Verilog. Thank you very much for your helping me out.
Here's another tip.... the following code won't work in simulation...
always @ (*)
  foo = 0;
The reason?  Since no signals are used in the block, nothing can trigger the block, so foo always
has a value of X.   Simulation and Synthesis will probably disagree.
If you plan to do much Verilog, I *highly* recommend that you study blocking and non-blocking assignment
usage.  It can be subtle!
John Providenza
