What circuit is exactly the DCM block in the BASYS2?
It could be possible the next circuit?:
in what circuit is based on the DCM block ? . .
All the application required information about Spartan-6 DCM has given in Chapter 2: Clock Management Technology in http://www.xilinx.com/support/documentation/user_guides/ug382.pdf . Did you refer that?
