What is the difference between TMDS and LVDS?
Hi.
Now I'm stuck on how to implement HDMI interface within Spartan6lx16 - FT256 -2C.
Currently I'm using the circuit as the below,.
and I made the UCF script as the below.
But I'm confused that which UCF define is correct to implement the HDMI? LVDS or TMDS ?
and I want to know whether HDMI female header circuit is correctly designed or not. If there is not problem, then which one should I have to use to ucf re-definition? What am I supposed to do to modify the ucf ?
Scholar drjohnsmith
Re: What is the difference between TMDS and LVDS?
As you have seen, the FPGA has a number of IO electrical standards,
HDMI
https://en.wikipedia.org/wiki/HDMI
is as you know, a specification for connecting equipment,
HDMI, specifies to use for one of its interfaces a form of
Transition-Minimized Differential Signaling (TMDS)
https://en.wikipedia.org/wiki/Transition-minimized_differential_signaling
You will note that the FPGA IO is just the voltage / current specification,
     whilst the HDMI / TMDS specification covers other things sch as line encoding, 4b/5b encoding
One specifies the electrical IO standards of the FPGA in the UCF,
     and TMDS is not one of the options, as TMDS is as mentioned,  not just electrical but format.
The example of the UCF you give thus can not have TMDS as an IO standard.
Scholar drjohnsmith
have a look at the chips data sheet
there is no IO standard of TMDS.
https://www.xilinx.com/support/documentation/user_guides/ug381.pdf
@drjohnsmith
What does there is no IO standard of TMDS mean?
What is the 36 page Differential I/O Standards ?
Scholar drjohnsmith
HDMI
