Visitor sjgallo
What is the most recent version of ISE that supports the Spartan 2
I have an old FPGA dev board with a spartan 2 that I want to use but I need to know which legacy version of ISE to install.
Re: What is the most recent version of ISE that supports the Spartan 2
@sjgallo,
See if this helps: AR62380
Use one of the supported OS given here: AR18419
Nupur
@sjgallo
Use ISE 10.1.
Check this AR for details: 15938
You can download it from here: Download
You can get the registration ID from here: Reg_ID
Nupur
Visitor sjgallo
I tried that and it crashes on my W7 x64 machine.
@sjgallo,
Nupur
Visitor sjgallo
Very helpful!!
Thanks!
Visitor sjgallo
@nupurs
Is there an AR similar to #18419 that lists the ISE versions and the devices they support?
I know we have other dev boards here with older devices and I know this question will come up again for those devices.
You've been a big help.
Steve
Hi @sjgallo,
You can check the ISE software matrix: https://www.xilinx.com/publications/matrix/Software_matrix.pdf.
Thanks & Regards,
Prathik
Helpful answer -> Give Kudos
Hi @sjgallo,
Does this answer your queries with reference to this thread?
If yes, please mark the post which gave the solution to your primary query as an answer "Accept as solution" which would help other forum users in future looking for this solution.
Thanks & Regards,
Prathik
Visitor sjgallo
@prathikm
The pdf you referenced doesn't address my second question in this post.
It doesn't list the ISE versions and which devices each version supports.
Hi @sjgallo,
The AR#15938 as suggested by@nupurs mentions about this right?
Thanks & Regards,
Prathik
Visitor sjgallo
I hadn't looked at that.
Yes, AR#15938 has what I am interested in.
Thanks!
