Visitor ayush666
Xilinx ISE process block not getting implemented
Hello everyone, i am designing a synchronization logic block for a project, using a process and IF statements:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity logix is
  PORT (
            hcounter : in std_logic_vector(9 downto 0);
            vcounter : in std_logic_vector(9 downto 0);
            enable : in std_logic;
            request_read : out std_logic;
            request_load : out std_logic;
          debugled: out std_logic
end logix;
architecture Behavioral of logix is
signal htemp : std_logic_vector(4 downto 0) := "00000";
signal flag : std_logic := '1';
signal ledtmp : std_logic;
begin
process(hcounter,vcounter)
begin
        htemp <= htemp + 1;
        ledtmp <= '1';
if (vcounter = 525 AND enable = '1') then
        if (flag = '1') then
            htemp <= (others => '0');
            flag <= '0';
            request_read <= '1';
            request_load <= '1';
        end if;
        if ( (hcounter < 640) AND (vcounter < 480) AND (htemp < 32) ) then
            if (htemp > 16) then
            else
                request_read <= '0';
            end if;
            if (htemp = 31) then
            else
                request_load <= '0';
            end if;
        else
        end if;
    end if;
end process;
debugled <= ledtmp;
end Behavioral;
However, when i implement the top module, this block gets represented simply as a GROUND connection to all the necessary pins, when i view the RTL schematic. What could be the problem?
Scholar u4223374
Re: Xilinx ISE process block not getting implemented
Did you try simulating it? A quick simulation would have revealed the answer almost instantly.
The problem is straightforward. Consider request_read. The conditions needed for request_read to be 1 are (vcounter = 525) and (enable = '1') and (hcounter < 640) and (vcounter < 480) and (htemp < 32) and (htemp > 16).
These conditions can never be fulfilled, so it must be zero all the time. Same applies for request_load. ledtmp is never set to zero anywhere in the code so it's just tied off to 1.
Scholar u4223374
Visitor ayush666
Thanks! i did change the conditions a bit and it got synthesized this time. I couldnt simulate it because my timing margins make ISim run for ages! I have another doubt though:
process(hcounter,vcounter,enable)
begin
        htemp <= htemp + 1;
if ( (hcounter < 640) AND (vcounter < 480) AND enable = '1' ) then
            if (htemp = 16) then
                ledtmp <= '1';
            else
            end if;
            else
            end if;
else
end if;
end process;
In this process, i want htemp to increment at the same rate as hcounter, but only till a value of 31 and not the entire hcounter value. I have doubts that the way i've incremented htemp will not work. I want to request a read when hcounter reaches 16 and request a load when it reaches 31. For that reason, im using htemp that only counts upto those values.
