geoffryf
Xilinx spartan 3an Basic Help
Hi everyone,
I know how to write code in VHDL. However, I'm having some very basic problems
  1. How do I make Spartan 3an button map to my port-in in VHDL?
  2. How do I make a specific pin map to my port-out in VHDL?
  3. How do I compile and flash my VHDL into Spartan 3an using ISE Web Pack?
I am very confused with these basics. When I study computing science, they never teach us how to do it with FPGA.
Thank you everyone in advanced
efis
i suggest you look at the ucf file and the example file you got with your board you can see your pins and buttons and how to map them
about the compiling you should make a bit file and download it to your board you do that with a software that the vendor is providing
geoffryf
I lost all the documentation while moving my place. Do you know where I can find it?
Also, I had compiled a .bin file already. Is there any instructions on how to flash it into the FPGA?
Is there a sample step by step Hello world example for this FPGA?
efis
i just sent you a file that has all the pins in your card ( spartan-3A(N)) so now you can add it to any project and
edit it according your design
 regards
 efis
Tags (7)
