about spantan6 lx45 timing constraints problem
we are developing lx45's DDR3 controller with mig, but i find that there is no timing constraints on DQS, why not ,how can i add the constraints to may projects  i  there is some timing violations
Re: about spantan6 lx45 timing constraints problem
@wanglei770802
Spartan6 is a hard block, once you slect the controller , clock frequency etc in the MIG GUI the tool will genarte location,  clock and other required constarints.
You can view them in example_top.ucf lcoated in exampl_deisgn or user deisgn  par folder.
Other than this no other constarints are generally needed as the delays are fixed
If in case you see any timing violations in any of the MIG paths, let us know we can look into them
Hope this helps
-Vanitha
Hi @wanglei770802
You need not constraint MIG DQS pins. The calibration process will take care of delays on these paths.
Deepika.
@wanglei770802
Hope this helps
-Vanitha
