cable detection failure in Spartan 6
I am using Digilent NEXYS 3 board for my project purpose. When I am trying to program Spartan 6 using Xilinx ISE Design Suite 12.1 I am getting the following error.
GUI --- Auto connect to cable...
AutoDetecting cable. Please wait.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Driver file xusbdfwu.sys found.
 Driver version: src=1027, dest=1018.
Update completed.
 Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
PROGRESS_END - End Operation.
Elapsed time =      4 sec.
Cable autodetection failed.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
I have installed Digilent USB driver.  I am able to connect Spartan 3E board properly. But NEXYS 3 board is not getting detected! I am using Xilinx ISE Design Suite 12.1.
Can someone pls help me solve this issue.
Supin S
> I have installed Digilent USB driver. ... I am using Xilinx ISE Design Suite 12.1.
I believe that support for the Digilent cable was first added in the ISE 13.1 software, so using ISE 12.1 would not work.
Are you using platform usb cable II or digilent cable?
Vinay
Hi Vinay,
Thanks for the reply.
I am using digilent cable provided with NEXY 3 kit, and I connected it to the USB PROG port. At that time USB driver was installed.
Supin
Hi Supin,
I see that the drivers are installed correctly.
So can you try programming with a different digilent cable?
Vinay
HI Vinay,
I tried using another cable. But still not working!
I used digilent Adept and it is properly identifying the chip. So I think the problem is not with cable.
But when I am using Xilinx iMPACT, it is showing the same error..
I am able to connect Spartan 3E using platform usb cable II.
Supin S
