can i retrieve the VHD file from the bit file
Hi everyone,
I guess i lost a very important Vhd file,,,,all i have is the bit file...is it possible that i could retrive the VHD file from the bit file i have???
Thanks alot in advance
Instructor
Instructor
Re: can i retrieve the VHD file from the bit file
No, you can't.  .VHD is source code.  .BIT file is (moderately encrypted) object code.
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
-- Bob Elkind
SIGNATURE:
Summary:
Historian
Historian
@anassamir wrote:
Hi everyone,
That would require a miracle.
i thought so :D
Instructor
Instructor
i thought so :D
But you had to ask, anyway...
Has anyone thought of loading the .BIT file backwards?  This worked for the Beatles...
-- Bob Elkind
SIGNATURE:
Summary:
"Has anyone thought of loading the .BIT file backwards? This worked for the Beatles..."
Apparently that works only 1-in-666 times!
"If it don't work in simulation, it won't work on the board."
Does anyone know how to retreive a bit file from an FPGA after it has been loaded onto it?
Tags (2)
