can put 2 signal analog input throught spratan 3e
i have a project about adaptive filter, and i need 2 inputs analog to convert throught adc on spartan 3e ,but it must be simultanneously ,could it be ???
Re: can put 2 signal analog input throught spratan 3e
you can use two channel adc which are available in market
Anonymous
Not applicable
which ADC is so fast?? my project is active noise control so that the speed is very important to me
Historian
Historian
Specifiy how fast you need to run. Are you doing audio noise control or something else?
