Visitor adhouib
fifo example design used in fifo generator v9.3
I would like to implement a fifo
i referred to LogiCORE IP FIFO Generator v9.3 document (supported by spartan6 FPGA) and it is listed that there is a fifo exemple design but unfortunately i don't find any link or clear steps in this document to download/get the fifo exemple design .
could you please help me?
Please note that i use ISE14.7
Thank you.
Best Regards,
Re: fifo example design used in fifo generator v9.3
Hi @adhouib,
From PG057 page no. 210: https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v9_3/pg057-fifo-generator.pdf we can find the example design for the fifo_generator/v9_3 here:
The chapter 8 page no.186 of the same document describes configuration of this example design.
Prathik
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Hi @adhouib,
Prathik
Visitor adhouib
Hello Prathik,
Thank you very much.
Best Regards.
