Visitor adhouib
fifo example design used in fifo generator v9.3
I would like to implement a fifo
i referred to LogiCORE IP FIFO Generator v9.3 document (supported by spartan6 FPGA) and it is listed that there is a fifo exemple design but unfortunately i don't find any link or clear steps in this document to download/get the fifo exemple design .
could you please help me?
Please note that i use ISE14.7
Thank you.
Best Regards,
Re: fifo example design used in fifo generator v9.3
Hi @adhouib,
From PG057 page no. 210: https://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v9_3/pg057-fifo-generator.pdf we can find the example design for the fifo_generator/v9_3 here:
The chapter 8 page no.186 of the same document describes configuration of this example design.
Prathik
Helpful answer -> Give Kudos
Hi @adhouib,
Prathik
Visitor adhouib
Hello Prathik,
Thank you very much.
Best Regards.
