heat sink spartan6
I am looking for a heat sink for spartan6 LX45 FGG484-2 fpga with 1mm spacing between pins.
Would really appreciate if some one can help.
Scholar drjohnsmith
Re: heat sink spartan6
have you tried your local retailer ?
RS components, digikey etc.
do you know how much power you need to get rid off ?
    how much air flow do you have ?
Instructor
Instructor
Almost as important as the heatsink itself is the method to attach it to the chip.
These people have some interesting clip attachments if you need to apply a standard heatsink
on an existing board with no special holes for a heatsink frame.  Your other alternative
is heatsinks with pre-applied glue (these have not worked well for us) and bonding the
non-glued heatsink using two-part epoxy (we use this solution in high volume).
-- Gabor
-- Gabor
Observer rho88
We've used Radian Heatsinks before for some Virtex parts and had pretty good success.  You might want to check them out
Teacher eteam00
FPGA cooling solutions
Some important questions:
  • Are you seeking a volume production solution, or a solution for a few boards?
  • Is this a new board design, or a retrofit to an existing board?
  • How much forced airflow is in your enclosure?
Your inquiry was lacking all of these important details, so I'll try to cover most of the likely possibilities.
If you need a production solution, the manufacturers are mostly in the Far East, and you should contact them through local sales reps and parts distributors (unless you happen to work in the Far East, yourself!).  If your annual volume is in the 1000s, many manufacturers will custom design a solution to meet your specifications.  They have a large catalogue of components (fans, heatsinks, pegs, springs, clips, etc.) which they can assemble into very economical assemblies.
If you are retrofitting a few boards, you might do some shopping on eBay.  The two high-volume (and relatively cheap) solutions are CPU coolers (for Intel and AMD processors) which handle 10s of watts, and video ("VGA") chipset coolers which handle up to 10W.  The CPU coolers are entirely inappropriate for FPGAs in most applications, of course.  The video coolers are quite effective and inexpensive.
Does your enclosure have forced air movement?  If so, a passive (no fan) heatsink may be completely adequate, and you eliminate the reliability risk of a cheap fan with cheap bearings.
If there is no forced air in your enclosure, and you are relying on natural convection for cooling, a passive heatsink adequate for your thermal requirements may be physically huge.  Passive heatsinks are not very efficient for heat transfer in still air.  On the other hand, it doesn't take much air movement to greatly increase the thermal transfer efficiency of a heatsink.  The addition of a cute little fan is usually enough to shrink a monstrous heatsink to the size of...  a video board cooler.
If you decide that an active cooler (heatsink plus fan) is the best tradeoff for your needs, you have another choice to make:
  • select a high-quality fan with long-life (more expensive) bearings (typically ball bearings)
  • select a cheaper fan with inexpensive (shorter service life) bearings (typically sleeve bearings)
Your selection may depend on the required lifespan of your product.
In a recent design for a volume production consumer product,  I selected a middle-grade fan, and I added a thermostat circuit for turning on (or off) the fan.  Because this product (a laser printer) is idling almost all the time, a thermal control extended the operational lifespan of the fan by several orders of magnitude.  An inexpensive FET is all you need for switching the fan power.  Add some hysteresis (e.g. 30 sec delay for switching off)  to avoid constantly switching the fan on and off.
If you select a cooler with a heatsink, the manufacturer will provide you with datasheets listing 'operating hours lifespan' for each of the various fans.  The lifespan claims are typically ridiculously unbelieveable.  A 50-cent fan with sleeve bearings is not going to have a 50,000 hour operating lifespan.
If this is for a new board design, you have the option of selecting from a number of attachment mechanisms.  Spring-loaded nylon pegs and metal clips are both quite popular.  You should obtain mechanical samples of your preferred solution before completing your circuit board design.  If you choose nylon pegs, evaluate the circuit board drill size and tolerance carefully.  If the holes are too small, the production folks will not be happy trying to attach the device.  If the holes are too large, the thing will fall off in shipment and rattle around your circuit board until the customer unpacks the thing (hopefully without first powering on the board!).
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
Re: FPGA cooling solutions
You probably missed the fine print where they say that the "operating" life assumes a 25% duty cycle operation
with a thermostatic control...
-- Gabor
-- Gabor
Teacher eteam00
Yup, gotta get new eyeglasses...
-- Bob Elkind
SIGNATURE:
Summary:
