Newbie 07703309975
intel strataflash parallel NOR flash PROM programming
hi all
 i need save image pixels in external memory on spatarn 35 statarboard and i chose intel strataflash parallel NOR flash  PROM (16MB) but i donot know how can store and read from it.
 can any one help me to use this external memory to store my image and read it ????
Re: intel strataflash parallel NOR flash PROM programming
Refer to http://www.xilinx.com/support/documentation/application_notes/xapp978.pdf
Hem
Newbie 07703309975
thank you
but this documentation use to store the MCS file  the INTEL strataflash PROM
 i use this PROM to store data not configration program .
Historian
Historian
@07703309975 wrote:
thank you @htsvn
NOR flash is easy to deal with. Read the fine data sheet which should detail the command set and then implement it in your FPGA.
Newbie 07703309975
thank you
can you give me the data sheet content detilas about command for flash???
please !!!!!
Mentor hgleamon1
Mentor
What part number is the flash?
Find out then use your favourite search engine to locate the datasheet. Inside the datasheet there will, without doubt, be a table describing the command set for that device.
"That which we must learn to do, we learn by doing." - Aristotle
