problem about A25-A0 of Spartan6lx100csg484 when configration
I used master selectMAP mode, pull down M1,M0 with 2.4K resistor, pull down CSI_B and RDWR_B with 1K resistor, connect  xc6slx100csg484 with XCF32P chip.   But the A25-A0 output signal when configration.It looks like the FPGA selcet master BPI mode.How can i solve the proble?thanks!
Re: problem about A25-A0 of Spartan6lx100csg484 when configration
Yes, during the selectmap configuration the Address pins A0-A25 toggle, but this must be taken care in your system during configuration. This is made a note in UG380.
are you facing any problem configuring from platform flash?
--Krishna
I used A4 as a switch signal. The signal must output low when power on and configration. Now it can not work correctly because the toggle. Can i set A4 to output low when configration?
