urmilagavale
problem in displaying image using spartan3E starter kit
 I have done vhdl code for color changing on monitor through vga port of spartan3E and it works successfully but i am not able to display image on monitor. As we have 5 out pins to vga i.e hsync,vsync,red,green and blue ,i am not understanding how to assign bits of pixel to red, grren and blue out of vga. which image format is compatible with vga. If we have 8 bits per pixel then how to assign this to out pins?
balkris
I think you need to convert color image into binary image. convert each 8 bit R, G, B into 1 bit binary image.
Hope it will help
Thanks and Regards
Balkrishan
balkris
Please refer the attached document. can you please send me your board ucf and datasheet .
--Bala
Thanks and Regards
Balkrishan
urmilagavale
Sir, this attachment is regarding spartan 3E's  vga ucf and vga timing.
balkris
This board only support 3-Bit Display Color Codes. You need to convert your 24 bit color image into 3 bi colors. Each bit represent one color. To convert the binary from 8 bit you can take threshold on 128 gray level . Any value above 128 bit you can represent '1' and else '0'
Thanks and Regards
Balkrishan
urmilagavale
Sir,
RGB3=uint8(IMG > 128);
 is it correct way to convert 24 bit color image into 3 bit color in matlab.
 or suggest me some links regarding that
balkris
which language you are using for your application.
RGB should be 23 down to 0 in VHDL
G = 23 down to 16
R = 15 down to 8
B= 7 down to 0
G_out = '1' when G >128 else
0';
R_out = '1' when R >128 else
0';
B_out = '1' when B >128 else
0';
G_out, R_out, B_out will be on top level and assign correct pin for these ports in ucf
Thanks and Regards
Balkrishan
urmilagavale
ok thank you i will try using this. thank you.
urmilagavale
sir i tried thresholding but no image is displaying.Only the screen becomes dark gray .
weimao
i have a question to ask you , can sparton 3E run some iamge processing program,such as edge detect, dialaton,and so on.
thank u~!
I thank everyone that helped me and give me advice.
may you all happy and healthy!
yenigal
You can try implementing for smaller sizes but as these devices doesn't have DSP blocks and low density devices these are not suitable for larger video sizes or video applications.
The Xilinx Video IP's are not supported for these devieces.
Satish
