yuan99zhou
problem with the cable connection in iMPACT
I'm a newer for FPGA. My os is  Linux r 2.6.26-2-amd64, and the xilinx ise is 12.4
when i connect JTAG  with  PC by cable , the error occured.
messages followed:
WARNING:iMPACT -  Module windrvr6 is not loaded. Please reinstall the cable drivers. See Answer Record 22648.
Cable connection failed.
PROGRESS_END - End Operation.
Elapsed time =      0 sec.
Cable autodetection failed.
WARNING:iMPACT -  Module windrvr6 is not loaded. Please reinstall the cable drivers. See Answer Record 22648.Cable connection failed.PROGRESS_END - End Operation.Elapsed time =      0 sec.Cable autodetection failed.
I found some cable drivers ,but it's useless. The iMPACT could't detect the usb.
How should i do?
Thank you very much!
eteam00
Professor
Professor
Suggest you search the forums for "usb cable driver linux".  This topic has been discussed quite recently.
-- Bob Elkind
SIGNATURE:
Summary:
eteam00
Professor
Professor
-- Bob Elkind
SIGNATURE:
Summary:
yuan99zhou
Thanks, I have solved the problem from the results!
