hirailyassahi
sp605 aurora protocol
i need a example design of four lane aurora protocol for sp605
umamahe
Please visit http://www.xilinx.com/products/boards-and-kits/device-family/nav-spartan-6.html  and check all the boards’ example reference.
venkata
The SP605 provides access to 4 MGTs.
• One (1) MGT is wired to the PCIe x1 Endpoint (P4) edge connector fingers
• One (1) MGT is wired to the FMC LPC connector (J2)
• One (1) MGT is wired to MGT SMA connectors (J36, J37)
• One (1) MGT is wired to the SFP Module connector (P2)
So you can test 4-lane aurora core in loopback mode.
Check XAPP1193 for guidance on what needs to be done to target the Aurora core to an evaluation board.
http://www.xilinx.com/support/documentation/application_notes/xapp1193-aurora-8b10b-on-kc705.pdf
